Results 1 to 6 of 6
Thread: To lift or not to lift that is the question
    Mar 2011
    1999, Astral
    It depends on how tall it's gone. If it's just a couple of inches I'd say there is no prob. OME rear and T bar crank is perfectly fine. With bigger tires and lil lift you get speedo off, and a little stiffer ride, maybe some MPG's will go away as well. The key word in this argument is "moderate." Don't go huge unless you want to do some real work. 2-3" no CV problems, steering problems, alignment should be done after lift, not hard to put back to stock, if the old owner did it it's probably just t bar crank and either spacers or new springs very easy to reverse.
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    Thanks, so a 3" lift should not be a deal breaker if the VX is a good deal for the money.
    Quote Originally Posted by CatFish View Post
    As long as the CV boots aren't torn, then I'd say go for it.
    Some ... not all VXs with 3" lift will start tearing CV boots very soon after the lift. If PO did the lift some time ago & there are no problems then I'd say you won't experience any in the future either.
    Unfortunately I wasn't one of the lucky ones. My CV boots tore soon after purchase & I had to do the diff drop. No problems since.
  1. another lift question...
    By xman in forum VX Modifications...
    Last Post: 10/13/2008, 02:59 PM
  2. lift question
    By drummysvx in forum VX Troubleshooting...
    Last Post: 05/30/2007, 02:28 PM
  3. Lift Question...
    By grober02 in forum VX Modifications...
    Last Post: 03/22/2007, 09:38 AM
  4. Lift Question
    Last Post: 04/28/2006, 01:28 PM
  5. Lift Question Please help
    By VXspaceship in forum VX Troubleshooting...
    Last Post: 07/08/2004, 06:17 PM
