Tapping does cause retard - I said advance drops, which I can see is confusing. My bad.
At around 22% TPS it is using 38° advance and there is mild activity on the knock sensor. 3% more TPS and ign is at 16° with no activity on the KS. That clearly aint max timing for that load....!
The CAS chopper wheel is on the crank inside the crankcase, and the pickup bolts into the block with no adjustment
Need to find a Supernerd who can take the time to dig thru it. Its a Delphi but we no speekee its lingo. As a side chore we are looking for which programmable GM ECU can interface. Ign is the sticking point - the one on the Gen IV Chev V8 comes closest so far in that the crank chopper is the same, but cam position signal isnt
