Ldub, Can I get some clarification on this here?
I have jacked up the car such that I had plenty of space to work, but did not actually raise the tire completely off the ground. In this position, I was able to remove the top shock nut and the lower shock nut. Since I have the wheel extended with the jack, I am able to physically compress the old shock enough such that I can actually remove the verticle pin from the upper frame hole. Doesn't this suggest that I have no pressure or torque on the lower bolt, and thus would not need to seperately jack up the lower control arm? Am I misunderstanding the forces and connection points?
What he say...
There should be a jackstand under the frame,(EVERY time a tire leaves the ground) then use whatever jacking device you're using, to jack up the lower control arm to remove any tension from the shock mount. Just a little at a time, until the pressure of the torsion bar is relieved from the shock mount.
A pickle fork can also come in real handy...
