Based upon the recommendation from you guys that replacing my own shocks was quite easy (you bastards!) I started the job this evening. Replacing OEm shocks with Ranchos. I got the top nut off easy enough, and with the help of a breaker bar I got the bottom nut off, but the bolt doesn't seem to be coming free. I am looking at my rancho replacement shocks and the bottom eye does not seem to be threaded, so why won't the bolt come out? I tried unscrewing it with my socket wrench, and granted that I don't have room for more than two clicks at a time, but after working it for some time I see no movement out of the holes. I tried hitting it with a hammer to no effect. Any recommendations?
