Has anyone installed Rancho 9000XL shocks with a 3 inch lift from Calmini, the homegrown kit with ball- joint flip, torsion crank, OME Springs or the very expensive Independent 4X kit? The Rancho catalog only list a stock replacement 9000XL Shock:
RS9000XL SERIES SHOCK Stock Front RS999214 qty.2
RS9000XL SERIES SHOCK Stock Rear RS999215 qty.2
http://www.gorancho.com/shock_lookup...dels&x=52&y=11
Has someone cross-referenced some 9000XL's to compensate for the lift? I tried to ask Independent 4X how they did it and got no reply. Here is one of the 3 inch kits using the 9000XL's:
https://www.independent4x.com/mercha...roducts_id=192
Calmini was kind enough to give me their shock lengths with their 3 inch kit FYI:
Front compressed 9.5 inches
Front Extended 14.5 inches
Rear compressed 13.5 inches
Rear Extended 21.75 inches
http://www.pureisuzu.com/99-01_3_lift.htm
Rancho 9000XL Stock Shock Specs for VX:
Front compressed 10.340 inches. Front travel-4.160
Front Extended 14.500 inches
Rear compressed 13.150 inches. Rear travel-6.100
Rear Extended 19.250 inches
. If you want maximum rear axle flex, you'll need to remove/disconnect the sway bar, get coil spring retainers & the longer shocks. Otherwise, the sway bar will be the limiting factor for axle drop & the longer shocks won't be very useful.
