Where is this sensor on my VX? My VX will not hold idle for more than 5 minutes when engaged in drive. Changed out the Mass Air Flow and the EGR for new. Had the vehicle running for over half an hour to reset computer, but as soon as I drove it, it died several times. Had to restart, several times with some backfire, just won't maintain idle when in drive. Diagnostics had the two parts mentioned as faulty prior replacement including the MAP ( manifold absolute pressure) sensor. But before I replace it, I need to make sure I can and know where it is. I am hundreds into the hole and not liking the results.![]()
