Results 1 to 14 of 14
Thread: What causes This !!
    Feb 2012
    2000 JDM. RedRock Pearl
    What causes This !!
    When the Air Con' is switched ON and the compressor kicks in (whether at idle or on the move)....what sensor/switch or thingymebob causes the engine Rev's to rise?..
    ..is it the ECU that sets the rev's ?...i guess the TPS must receive a signal of some sort but from where!!....what actually takes place to cause the RPM to increase the instance the compressor starts to put load on the engine?
    ps. there is a good reason for this question due to an odd erratic idle issue i have !....which appears to only happen once the A/C has been used
    Thanks, in advance, Phil.
    Subaru Forester STi (310 bhp/330 Lbs/ft) JDM heaven
    Feb 2012
    To add to the above, Is there an A/C Idle Control Module ?...if so, where is it?
    Sorry for all the questions but i think i may be closing in on the answer to my erratic idle...hopefully
    Thanks chaps
    Feb 2010
    2001,Kaiser,1130
    Have you checked the belt? Is the compressor clutch damaged? Can you live without air conditioning?
    Feb 2012
    Thanks for the reply...yes , the belt is fine, the compressor clutch is working, the Air con blows ice cold!
    I can live without it but over here it is also useful for clearing frost off windscreens as well as in the warm summers!..
    It appears my idle and running remain fine but when i use the air con..' it plays havoc! ...even if i then switch the A/C OFF it still idles at 1200 and surges when you least expect it
    Feb 2010
    2001,Kaiser,1130
    This may be getting you to do too much stuff, but I would get a voltmeter and check your battery voltage before and after you turn on your AC. Write these values down and see if there is any fluctuation.
    I once had a totally dead battery, and there was no idle.. As soon as I jumped it, it would die unless I held the gas pedal down. It must have been sending some really dirty power through to the ECU.
    Dec 2010
    2001 Proton Yellow VX 1268
    I think what your asking is are there two idle air control motors. There is only one. When the ECU sees the AC on it sends out a signal to the idle air control to raise the idle to help with the increased load on the engine when the compressor is running. If you have an erratic idle during the time when the AC is on it maybe due to the IAC needing cleaning. Remove it from the throttle body and clean the carbon off cone end with carburetor cleaner. Also clean the throttle body were the motor goes in to. See if that helps. It doesn’t cost much and can't hurt
    Twostep (Phil)
    Feb 2012
    Quote Originally Posted by twostep1n2 View Post
    Well done buddy, that is the answer i was looking for
    So my thinking was kind of right!..it is the ECU which detects the extra load on the engine and raises the rev's (via the IAC) to a higher level.
    A further two points.. I have already given the IAC a very good clean (the cone pintal and the whole throttle body) bare in mind, my motor has only done 37K miles and it all looked very clean anyway!!
    Secondly, when stood at idle, the Revs increase to 1700 when the A/C is on...this seems way to high for me?..
    ..Furthermore, when driving along, if i am slowing to a stop and the A/C compressor kicks in, this causes the revs to rise far to much and the car momentarily surges forward ....this can be a bit unnerving if you are only feet from the car infront
    Questions: Why do the rev's increase so much when the A/C compressor kicks in? And if it is the ECU which determines this, how can i stop it?
    Dec 2010
    An erratic idle can be caused by a number of things. Only one of witch is the idle air motor. It can also be caused by a vacuum leak. There are several threads on the subject try a searching on "Idle".
    Feb 2012
    Well, i have looked at and cleaned just everything i can lay my hands on under the hood!...even had a can of BG44K through the fuel tank.
    I must say, when the Air con' is not 'ON' it runs really sweet (idles around 750 rpm in neutral)....When the A/C is ON it does now seem to drive better while on the move but you can still feel a slight surge in revs when the compressor cuts in but it does not seem so pronounced as it was....nevertheless, it is still there!
    I guess i will just have to live with it.......does anybody know if there is a particular vacuum pipe which is related to the Air con'.....in the sense that it would have an effect on the revs of the engine when the A/C is ON (if it is solely the ECU that governs the idle speed when the compressor is working, then there will be nothing i can do about it? !)
    Sounds like i could do with an Automotive Air Conditioning specialist
    Cheers guys and thank you very much
