Got my Rancho's from Amazon. My primary mechanic gave me an off the cuff of $40 each for install. Tire Kingdom wants $250 total. So: is $160 reasonable or should I expect to find cheaper if I hunt around?
On a hoist with proper tools...
...the whole job is only about an hour , maybe hour & half .
So...$120 max IMO.
I would do it myself. 6 bolts. Probably a 2 on a 1-10 hardness scale!
Sears charges $20 a shock.
Does it require a torq wrench or can i just tighten it down "pretty tight"?
You probably don't absolutely need a torque wrench, but this'll give you an idea of what you need for each one.
The stock shock torque settings are-
Front- 14 lbs. upper, 61 lbs. lower
Rear- 70 lbs. upper, 58 lbs. lower
Mark
harbor frieght torque wrench...$10
Local shop wanted $300 for installation and NTB wouldn't install new shocks from Amazon, but was willing to buy them from their supplier and install for $750.
Fuzzy
2001 Proton #1413
Kaneohe, HI
Harbor Freight torque wrench = JUNK!! Buy a quality wrench.
I dont think 14ft lbs is enough to even get the upper bolt threaded onto rancho9000s. Ive installed 3 sets of them and there is always paint on the threads that make the top nut a pain. Just takes some force but it always goes. Didnt even take my wheels off for the last set
