Results 1 to 12 of 12
Thread: How much should I expect to pay for installation of my ne Rancho 9000s?
    Feb 2009
    2001 Proton Yellow VX 0938
    Got my Rancho's from Amazon. My primary mechanic gave me an off the cuff of $40 each for install. Tire Kingdom wants $250 total. So: is $160 reasonable or should I expect to find cheaper if I hunt around?
    On a hoist with proper tools...
    ...the whole job is only about an hour , maybe hour & half .
    So...$120 max IMO.
    I would do it myself. 6 bolts. Probably a 2 on a 1-10 hardness scale!
    Jan 2010
    2001 black 1145
    rancho
    Sears charges $20 a shock.
    Feb 2009
    Does it require a torq wrench or can i just tighten it down "pretty tight"?
    '99
    You probably don't absolutely need a torque wrench, but this'll give you an idea of what you need for each one.
    The stock shock torque settings are-
    Front- 14 lbs. upper, 61 lbs. lower
    Rear- 70 lbs. upper, 58 lbs. lower
    Mark
    harbor frieght torque wrench...$10
    2001 Proton Yellow #1413
    Local shop wanted $300 for installation and NTB wouldn't install new shocks from Amazon, but was willing to buy them from their supplier and install for $750.
    Fuzzy
    2001 Proton #1413
    Kaneohe, HI
    Sep 2010
    1999 white iron man 1728
    Harbor Freight torque wrench = JUNK!! Buy a quality wrench.
    +1, very simple install.
    ...and an impact wrench makes it a 1 out 10 on the difficulty scale.
    Quote Originally Posted by deermagnet View Post
    Mark
    I dont think 14ft lbs is enough to even get the upper bolt threaded onto rancho9000s. Ive installed 3 sets of them and there is always paint on the threads that make the top nut a pain. Just takes some force but it always goes. Didnt even take my wheels off for the last set
    *2
    Torque on those bolts is not critical. As tight as you can get them with an 8" box end wrench will be plenty. I doubt you'll even need locktite on them.
  1. Should I expect and plan for the worst?
    Last Post: 04/30/2013, 12:08 PM
  2. need pics of how much I should expect to trim with new tires
    By p_justin13 in forum VX Modifications...
    Last Post: 09/08/2011, 08:31 AM
  3. Rancho RS5000 vs Rancho RS9000XL
    By Pepino in forum General Tips...
    Last Post: 12/11/2008, 09:18 PM
  4. Rancho 9000 Installation Problems
    By CrzyFool in forum VX Modifications...
    Last Post: 11/15/2007, 10:16 AM
  5. Help On After HID KIT Installation...
    By Lizardmen3477 in forum VX Troubleshooting...
    Last Post: 11/01/2007, 08:49 PM
