Results 1 to 3 of 3
Thread: Help, I stink at electrical. Where to ground a CB?
    Mar 2010
    2001 Ironman 0588
    Against my better judgment, I'm installing a CB myself. Right now my plan is to wire the power into to the cigarette lighter so it will power off with the accessory switch. If I'm reading the electrical manual correctly (page 27 of the PDF), the power wire is brown/white. But... where should I ground it? Is a good clean connection to the firewall OK? Or, should I wire into an existing ground wire?
    Any metal bolt going to the body/frame will work fine. Just make sure the ground wire is touching metal and not paint. You can also use the ground wire for the 12v outlet, I believe that's what I did for my cb.
    yup, its been a long time, but i think the VX has an orange and a black on the cigarette lighter.
    Either way, when you get to the back of the lighter one of the two wires will be the shielding and the other will be the 'center post'. The center one is the +, and the shielding is always negative.
  1. Ground Wire Kit
    Last Post: 10/15/2008, 08:48 PM
  2. Better Battery Ground?
    By k4tmc in forum VX Modifications...
    Last Post: 02/15/2007, 12:11 PM
  3. Amplifier Ground Question...
    By biju in forum VX Talk...
    Last Post: 05/08/2006, 08:55 AM
  4. What up with the Ground system?
    By AndyC in forum VX Talk...
    Last Post: 05/22/2004, 10:20 AM
  5. Any input on this??? Ground Kit??
    By xdfarrx in forum Meets...
    Last Post: 04/25/2004, 03:33 PM
