When you remove the cladding, there are these "brackets" (for the lack of a better word) that are somehow attached to the cladding. These brackets hold a white plastic fastener that will pop in/out of the frame of the vx.
I followed instructions very carefully and took my time removing the cladding (to have it sprayed with Linex). These things are a bi**h and a half. The plastic screws w/grommets underneath are a joke. I had to drill them out. Are there better ones made by someone else as opposed to what I will get from Merlin?
When I was removing the cladding, you want to pull from the bottom and POP out the fasteners from the frame and then pull slowly at the top where the tape is.
As I was removing the cladding, at least ONE FREAKING "BRACKET" came off of each piece of cladding that I've removed (4 pieces so far).They didn't break off, they just came off as if they were glued or something.
What type of "glue" or adhesive "stuff" should I use to reapply the ones that came off? I will also use this stuff to reinforce the others.
What kind of double-sided adhesive tape should I use when reapplying the cladding, or is it even necessary?
