Results 1 to 8 of 8
Thread: '99 Vehicross Engine Knock / Engine Replacement Suggestions
Flurry_Chris '99 Vehicross Engine Knock /... 02/25/2012, 08:23 AM
VX KAT Unfortunately there's been... 02/25/2012, 08:39 AM
vt_maverick Axioms were manufactured from... 02/27/2012, 05:58 AM
Flurry_Chris VX KAT, Thanks for the... 02/25/2012, 08:58 AM
VX KAT That's a real common scenario... 02/25/2012, 09:27 AM
H3_VX If a person has had NO oil... 02/26/2012, 07:27 AM
atilla_the_fun The PCV is something that is... 02/26/2012, 07:53 AM
Gussie2000 It's very important to make... 02/25/2012, 07:35 PM
    Aug 2010
    01 Foxfire Red Mica VX 0441
    That's a real common scenario in many of these failures. Many believe when there's no dripping, and no burning (smoke out the tailpipe) , that it's often related to the PCV valve. PCV =Positive Crankcase Ventilation, it's part of the emissions control system, but if it gets stuck (open IIRC), it allows the oil to be kind of sucked out.
    When the oil is lost through the PCV valve, it's not "burned" and not blowing smoke from the exhaust...it's getting sucked out in vapor form through the PCV. The oil is going into the injection plenum and being burned off moderately.
    It's like a $4 part, available at any autp parts stores..
    Because of this belief (not confirmed, but many think it's true), many of us replace our PCV valve every other oil change. I actually do it every time, since I think it might be cheap insurance.
    Yet some owners have never changed their PCV after thousands and thousands of miles with no problems.
    My '01 with 77k doesn't consume a drop until I hit the highway for about 8 hrs straight.
    You can change it yourself, super easy...
    Here's a "How-To" I did:
    http://www.vehicross.info/forums/sho...7&postcount=13
    THE OEM PCV IS THE RUST COLOR THING, RIGHT ABOVE CYLINDER #3 ON THE DRIVER'S SIDE. CAN SEE IT AFTER YOU REMOVE THE PLASTIC ENGINE COVER.
    IF YOU HAVE A RUST COLORED ONE, IT'S "LIKELY" THE ORIGINAL ONE INSTALLED AT THE FACTORY.
    If a person has had NO oil usage in 80,000 miles should one still change the pcv?
    2001 VX
    Mods
    2008 HUMMER H3
    Feb 2010
    2001,Kaiser,1130
    Quote Originally Posted by H3_VX View Post
    The PCV is something that is periodically changed, it isn't meant to last forever on any vehicle. Take yours out, and rattle it around. There is a little ball on a spring inside. If you can hear the sound, it is still OK - if not then you should replace it.
  1. Yet another engine tick/knock thread
    By Knigh7s in forum VX Troubleshooting...
    Last Post: 11/16/2013, 09:51 PM
  2. Engine Knock
    By Crasca in forum VX Troubleshooting...
    Last Post: 11/12/2012, 06:32 AM
  3. Engine Knock Vs. Timing Belt Tensioner
    By SilverBullet75 in forum VX Troubleshooting...
    Last Post: 01/01/2011, 06:11 AM
  4. Engine Code P0171-any suggestions?
    By drdavidr4u in forum VX Troubleshooting...
    Last Post: 03/02/2005, 05:31 AM
  5. Replies: 1
