Results 1 to 5 of 5
Thread: fuel problem
    Jul 2010
    99 sliver vehicross 0969
    fuel problem
    check engine light has been on for almost a year now it says its running lean... i changed the fuel pump fuel filter the fuel strainer checked the mass air flow sensor its ok check the injectors there ok what else am i missing please help thanks
    Codyman checking out!!
    Prolly intake gaskets...
    Or other un metered air entering through cracked/loose vacuum lines etc.
    Get out there under the hood with a can of starting fluid (ether) or other VERY flammable spray can (carb cleaner being another), & spray here & there around the engine...like under the intake, by the injectors, etc.
    Listen for an increase in idle speed.
    , & be careful playing with flammable stuff...
    Feb 2012
    2000 JDM. RedRock Pearl
    Good call with the easy start fluid sprayed around both intake manifolds (they are prone to letting go!!!)
    I assume you have had it on the Diag' tool ?...why leave it for a year?..guess it can't be to bad if it is still running acceptably for you....although running lean is never a wise thing for long term reliability
    '01 Ebony #0939
    Quote Originally Posted by codyman3487 View Post
    Fuel pressure regulator? It's relatively cheap and easy enough to replace anyway, so that might be worth a try too.
    Feb 2009
    1999,silver, 1516
    You say you checked the mass airflow sensor. How did you check it? Mine was running lean and I fixed it by pulling the MA sensor and spraying it thoroughly with MAF cleaner on both sides. Just a thought.
  1. Help: How to Replace fuel lines going to the fuel rails.
  2. Driving problem fixed/TOD problem realized
  3. which fuel?????
    By jacobus in forum VX Talk...
    Last Post: 09/20/2005, 10:53 AM
  4. Fuel lid
    By jstein in forum VX Talk...
    Last Post: 11/25/2004, 07:47 AM
