Results 1 to 15 of 27
Thread: Front and rear (rear) driveshaft joints are different?
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Ah I see. Well then great fix :-) Sorry I was assuming you were slightly lifted already.
    I lengthened the lower links almost a full inch and I could not see the threads, but then I lengthened another turn and you could begin to see the spline coming out of the rubber cover thing. I had the driveshaft place look at it and he said he can lengthen the shaft for me, so that is on my to do list.
    Keep in mind it comes out further when the rear axle drops during use.
    As for the fix, I wonder if I should post in the Talk forum. It would be interesting to see how many people might be ignoring this problem. The other unit I've driven in town also had some vibration in the rear (though I could only feel it vs hear it.) Seems like his could use a new u-joint or two. And, he's got a 3" lift with links.
    The other reason to post in Talk is I originally thought the characteristic vibration of the 6VE1 around 2200-2500 rpms was transmitting thru the drivetrain. I had a whole big thread on the vibration about a year ago. Any repost would serve to resolve that issue/thread.
    I dunno what percent of forum users refine their viewing to selected forum topics...
    All I know is, I go straight to the home page, & all active topics are right there to pick & choose.
    Feb 2010
    Thanked: 19
    Yeah, if you login often enough, the recent topics option is really the best. Probably not what prospective buyers see though. Initially, I looked mostly in the talk forum and the for sale forum.
    While I'm on the u-joint/driveshaft topic, I'd like to hear a bit about the front shaft and it's considerations. Also, it looks like it uses something else other than u-joints to perform the same task. Could someone tell me a bit more about that?
    Thanks!
    gp
  1. Front and rear TOD sensors
    By mattyism in forum VX Troubleshooting...
    Last Post: 04/04/2016, 02:36 AM
  2. TOD Front and rear sensor
    By The Claw in forum VX Troubleshooting...
    Last Post: 04/25/2014, 12:07 AM
  3. TOD and no rear driveshaft....
    Last Post: 09/03/2011, 10:38 AM
  4. Need Front and Rear Diff low down.
  5. front/rear cladding
    Last Post: 10/19/2005, 09:21 AM
