Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 54
Thread: Trans fluid??
    You can actually get the pan off without removing the cross member if you use a swivel socket but the trans mount has been known to loosen up over time so it is always a good time to check it.
    Good to know and excellent suggestion on the trans mount!
    Jul 2004
    1999/black/VX/black
    Quote Originally Posted by p_justin13 View Post
    Need to change any suggestions on best fluid to use?
    Thanks
    I am using Mobil 1 ATF
    '01 Ebony #0939
    Mobil-1 ATF here also.
    With synthetics, it's not just how similar they flow at normal operating temps when compared to regular fluids, it's how well they maintain their viscosities throughout their entire operating range. If you've ever added regular oil to an engine when it's around zero degrees F outside, you've seen how differently it pours when compared to adding it during the summer months. And on the opposite end of the scale, synthetics are designed to also maintain their flow characteristics when hot.
    This applies to any full-synthetic fluid though, not just Mobil-1.
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    I got my VX about 3-4 yrs now. I had the trans fluid changed immediately as part of a check list of things I did. I haven't changed it since. I've been told that since it's been so long that I should change it or it will kill the transmission. Is this true?
    Ty
    '01 Ebony #0939
    Quote Originally Posted by tysamigo View Post
    Trans fluid and filter in transmissions is just like engine oil in engines. There's usually a timeframe/mileage recommended by the manufacturer for when they should be replaced.
    Transmission fluids and filter changes for automatic transmissions are generally recommended at around 60k miles (after new, or, since they were last replaced), but individual driving conditions and type of fluid can change those time periods and mileages.
    Mar 2010
    2001 Ironman 0588
    Atilla mentioned to "be cautious" before agreeing to a transmission flush. To elaborate, there have been several posts here where people suspect that a flush may have lead to failure of their transmissions. Some advice says to avoid it unless you know it's been done on a regular basis.
    You may have already read this, but just in case others read this thread in the future, I thought it was worth mentioning. Search for "transmission flush" for more details.
    Thanked: 15
    This is what I've heard. I got the Proton 3-4 years ago with 25k miles. It now has 94k miles. I had the fluid changed once when I first got it and haven't changed it since. Would it be ok to change now you think?
    Jul 2009
    With 70,000 since the last change, now would be a good time to change the fluid and filter. I bought mine with 150,000 miles and changed the filter and fluid to Amsoil Synthetic ATF with only good things to say about the trans performance since then, no horror stories or doom and gloom! I would NOT flush it though, too many reported problems with that procedure, usually resulting in transmission failure...
    Vixer Fixer
    Jul 2004
    1999/black/VX/black
    X2
    Jul 2010
    1999,silver,VX,0118 & 1144
    I have the fear of doing a change, only because in the past, the vehicle always ran funny afterwards. I bought all the parts then I was reminded how things run after filter changes. Has anyone experienced any problems after the filter and fluid change?
    Quote Originally Posted by jmayer40 View Post
    I had the Check Trans Temp light come on ONCE only a few hours after I had the work done. I posted here and a few others had the same thing. It has not ever come on again and it runs/shifts great.
    '01 Ebony #0939
    ...Has anyone experienced any problems after the filter and fluid change?
    I changed my own filter and fluid to synthetic not long after purchasing my VX and haven't had any problems. My VX doesn't get subjected to much severe duty though (towing, extensive off-road 4x4 usage, etc) so a VX operating under those conditions will also require more frequent trans fluid and filter servicing.
    Feb 2010
    2001,Kaiser,1130
    Mine actually shifted smoother after the filter change, it was a slight change - but perceivable. The filter was very very dirty, very clogged. I never had the temp light issue - and the job went smoothly, except removing the old gasket from the pan mating surface. (it took a long time). Support the transmission with a jack, drop the crossmember with a socket and a breaker bar, drop the pan, remove the old gasket, change the filter, put a bead of RTV on the mating surface and set the new gasket, then put the pan back on with the new filter installed. Repeat for the second pan, then refill the pan with ~7 quarts of synthetic ATF.
    Wash the pans with brake cleaner to remove the metal shavings which inevitably coat the bottom of the inside of the pan.
    I have always been told that rtv or the likes is a no-no on trans gaskets. If small pieces of it dry out and break free they clog the small passageways and cause problems by restricting/blocking fluid flow.
    Feb 2010
    2001,Kaiser,1130
    The filter is right on top of the pan, and I didn't see any small passageways in the area that isn't beyond the filter, but I'll keep an eye out. The bead size I used should not have exceeded the mating surface, even when pressed.
  1. Checking Trans fluid
    By ahdoman in forum VX Troubleshooting...
    Last Post: 08/04/2014, 09:11 AM
  2. Trans fluid change oil temp question
    By Tornado in forum VX Troubleshooting...
    Last Post: 07/17/2013, 02:12 PM
  3. checking the trans fluid
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 12/06/2007, 01:16 PM
  4. Trans fluid change - caution
    By marcosv6 in forum General Tips...
    Last Post: 04/04/2007, 09:36 PM
  5. change trans fluid?
    By zadam123 in forum VX Talk...
    Last Post: 11/03/2004, 03:53 PM
