Vette,
The wear points are the inner & outer races & the bearings themselves. The cage shouldn't wear but if the joint has been running dry for a significant time then it could have wear as well. I'm not familiar with the Empi shafts so I don't know what OEM parts they are compatable with.
Good luck with your surgery & relocation. A buddy of mine at work had similar surgery a few years ago with a quick recovery & no adverse effects. IIRC he had a small tumor on his pituitary gland.
Recently, in another thread, I mentioned my confusion about the EMPI shafts having different size balls (bearings) than stock. This didn't seem possible/likely since they need to correctly mate to the "receiving end" of the joint. If not, I can't see how they wouldn't pop and wear inappropriately.
I'm expecting the Empi's to bolt right in...and be compatible with OEM parts.
I hadn't thought of anything like a race but I don't think any bearings are bad. Don't hear any of that type of noise anyway. I just want to have them on hand for the mechanic. And, for jobs like this, you always wonder if a new bearing race (along with any other reasonably-priced parts aren't better replaced during the operation.
Speaking of operation,,,my tumer is getting pretty big. I think doctors let it go too long as it's over an 1" in diameter. Not looking forward to it...but know it's gotta be done. I appreciate the vote of confidence though!
