Results 1 to 15 of 23
Thread: Gear Whine, is it normal??
    Oct 2012
    00, Dragon Green, 0366
    I just purchased a 2000 Vcross with about 63K on it. I have had several 4WD vehicles but never noticed the gear whine like on this beast.
    When accelerating it sounds great, but as soon as I let off the accelerator the gears start whining. When I decelerate it gets downright loud!!
    Is this the norm??
    It sounds a lot like my 6X6 Pinzgauer!!!
    Nov 2007
    1997 SILVER
    Welcome to the club.
    Definitely not normal.
    With my music off, the loudest noise is tyre noise on the road - what tyres are you running??
    Other suggestions would be a lift done badly, or no lubrication in the 3 grease nipples in the rear drive shaft.
    If you have the technology to do record the noise, you could post it up for others to comment on.
    Good luck with it.
    PK
    Dec 2011
    2000 proton yellow vx 0610
    Quote Originally Posted by boelt63A View Post
    Is this the norm??
    Check your tire pressures! Try to keep them within 2lbs. I get a gear whine when slowing down if one of the front tires is low on air.
    Also, get on your knees in front of your VX. After thanking the Lord for blessing you with such a sweet ride, look at your front axle. Are all 4 of the CV boots in good shape. When one of my inners went TU, it sounded like a lawn mower whenever decelerating. By the time I found it, the boot was torn in half, there was no grease in the CV and the joint was toast.
    Jul 2012
    Also, make sure your 4Lo is completely disengaged. I had the whine on my VX when I first got it and I found out that it was from the previous owner placing the rig into 4Lo and back into 4Hi but the Lo didn't disengage completely until I was on a hill going upward... It's weird. Probably due to him never using the 4Lo and it could be in need of some lube.
    Mar 2012
    sold
    i had the same type of noise noise when i bought mine but it was fixed when i bought 4 new matching tires and made sure the pressure was equal in all of them - thanks to this website i knew that this was most likely the problem but i used that fact to get a better deal
    Oct 2012
    Thanks for all the info!!
    I will check the tires and boots but this definitely sounds more gear related. Coming from the rear more than front and equal; not one side more than the other. Worried that it is differential. The transfer case was rebuilt right before I got the truck so I really hope it isn't that!
    Mar 2012
    sold
    i would love to drive about 5 different vx's jsut to see the differences (if any) - its so hard to diagnose such a rare vehicle when you have no comparison - mine is the only vx i have ever seen in person so i really cant tell if its nice or a p.o.s. - either way i like it a lot
    Ive driven multiple VX's and each one is different, but probably more due to modification level.
    Moab is always a good chance to ride in VX's.
    I think so far, sue's vx was the smoothest one ive been in.
    Oct 2012
    Mine might be a POS but I think I am going to enjoy our time together! Basically it is a Stock truck with relatively low miles on it. I snatched it up from a Honda dealer who got it in trde for something. They re did the transfer case before ibought it but it still makes some noise. Benefit of getting it from a dealer is that I got a 3 year 36,000 mile warrantee on it! But I want to avoid any major problems if you know what I mean.
    May 2012
    2001 Iron Man,Vehicross,0814
    Mine makes a whining sound (more like a deep sigh) when I am slowing to a stop. I have given up some years ago worrying about this kind of stuff. It will break and then I'll know what it was, lol.
    Oct 2012
    @ Maddawg, I like that mentality!!
    May 2012
    Thanks, cause I was sure I would meet with a lot of negativity over that remark.
    Jun 2012
    2001 VX 0244
    Mine sounds like a pencil sharpener when I slow down, it's not the brakes. Gave up on it. Some day it will be a grind then a sequel or thud. Then I'll know what it has been all along.
    May 2012
    Quote Originally Posted by rockhavok View Post
    Or it'll just fall off, heheh.
  1. Is this normal
    By bssage in forum VX Talk...
    Last Post: 08/14/2012, 05:55 AM
  2. Is this normal?
    By ibmx2 in forum VX Talk...
    Last Post: 09/23/2010, 07:26 AM
  3. is this normal??
    Last Post: 02/19/2007, 09:27 AM
  4. Is this normal?
    By Mikeys00vx in forum VX Troubleshooting...
    Last Post: 11/20/2005, 07:58 PM
  5. Differential whine
    By PBR in forum VX Troubleshooting...
    Last Post: 05/28/2003, 04:50 AM
