Thank you Tom!
That's perfect!
Thank you Tom!
That's perfect!
SilverBullet75
Formerly: '01 Ebony VXSTLTH
Now: '08 Saab 9-7x Aero 6.0L
The NAPA unit pictured by SilverBullit shows at least 3 ball bearings in view. I'd assume the other 3 are present on the backside of the pic. Am I misunderstanding your point?
OK. I looked at the bearing repack procedure. Once the hub is pulled, I assume you're telling me the CV "halfshaft" free to come out?
Been there... failed trying that.
The aftermarket tripod style CV does not fit our green CV cup. You will get tripods if you order the half shaft + jack shaft (inner shaft) together. Since the tripods are much beefier than our six ball bearing rzeppa CV, I thought it would be a nice upgrade for strength. I was able to purchase both tripod jack shaft from EMPI (you cannot buy rzeppa aftermarket) along with two half shafts. I found that the tripods would bind at IFS droop which made the ride harsh, clunky, & truthfully made the VX worse. The project was a big waste of time and money.
Since I can't buy the rzeppa cup jack shaft aftermarket, I have a backup set of jack shafts from a VX. I suggest that anyone who's lifted & goes wheeling do the same. You can get rzeppa jack shafts from most ISUZUs: Trooper, SLX, Rodeo, Amigo, passport, & VX
If I understand the design correctly, the CV axles drive the front wheels thru those bearing-to-groove slots in the joints. IOW, they act just like a gear, interlocking to move the axle.
While I understand how the design allows for 360-degree articulation of the wheel, there's one thing I'm not sure of....
In my past experience with a failing CV joint, I know exactly what a popping joint sounds like during a turn. I know how to tell when a FWD unit sounds when it's failing. My question is whether it's the same for 4WD.
Is it possible for failing CV joints/axles to make noise similar to a wheel bearing noise WITHOUT having the classic popping sounds while turning?
I notice some mild vibration around 55mph. In a thread about 1yr ago, I proposed it might be engine noise. But, I've yet to confirm that. Many talk about the noisy hwy performance of the VX, but I'm still not willing to give up on any possibility.
Any opinions on the possibility of CV joints making noise running in a straight line?
The CVs can cause vibrations if they're going bad.
First, I would check the u joints on the drive shaft as they will definitely cause vibrations if you don't grease them regularly.
..and put the VX in 4lo on an appropriate surface & make some circles. If you have CV problems, you'll hear them click/pop.
Ditto what VXorado said.
When my inner CV boot ripped, and I didn't catch it until it was too late, I was getting some vibrations at various speeds that I thought was a drive shaft issue or a transmission mount issue. Got under the VX, greased the U-joints, and slip joint in the drive shaft, checked the transmission mount bolts and still had the vibrations. Checked the CV joints on the front axle and realized that the boot was torn, and gunk had gotten in there and effed up the joint. Had to have the green cup removed and re-machined.
Since the front axle is hard mounted to the frame, I was feeling the vibrations from the bad drivers side inner CV joint in the floor boards below my feet.
Also, check the transmission mounting bolts. Others have had some vibrations, or clunks, due to the bolts backing themselves out allowing the transmission to move around.
One more shot in the dark; check your engine mounts. If one is bad/broken it would allow things to move around and possibly cause a vibration.
Or...
They weld the scarring and then re-machine the inners. I believe it littlebeast had that done.
Sorry, must have totally missed this earlier.
You are right. When my boot tore and I didn't replace it relatively quickly, junk got into the green cup and as things moved around without grease the green cup got pitted and scarred. The green cup is just that; it's a straight walled "cup" that has grooves in the walls. Can't think of the best way to put this, but the grooves run from the bottom of the cup up to the lip of the cup. When everything is together in the VX the cup lays on it's side so the grooves run horizontal (parallel to the ground). The balls of the CV joint them seat into the grooves so that they can move in and out (parallel to the ground), but can't go anywhere else. As the cup rotates the balls must rotate with it because they are in the grooves, and that is what transfers power to the wheels. Does that may any sense?
Bart has a great write-up with pictures, and as "they" say; picture are worth a.....you get it:
http://www.vehicross.info/forums/showthread.php?t=21040
Like Billy (Triathlete) said, the front axle was removed and sent to a machine shop where they welded up/ filled in any of the pits or scars and then re-machined everything back into spec.
No, Pogoplug is great. I took the pics down a while ago.
Note: after months of having the Napa shafts on, I don't recommend them unless your cups are replaced as well.
Bad vibration since day 1.
That's too bad. NAPA said they use A1 Cardone's. I guess EMPI's really are better? I'm guessing the green cup end didn't fit tight or something? Otherwise, it doesn't seem like they'd cause vibration.... Hmmm....
BTW...I thought that picture of the halfshaft was the key to my understanding in that thread. I always think it's unfortunate to kill picture links.
