Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Taking a few cranks to get started
  1. #16
    Bart, just a heads up; I'm like you and I want everything that I put into the VX to be standard Isuzu issue, but Merlin want's something like $150 for the FPR whereas the one I got from NAPA fit perfectly, works just fine, and only cost $60.
    Just sayin'.....
    Hmmm, yeah. Perhaps I will go that route. What brand is it? Napa Gold or something else?
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    Mine does this too.
    Only after I swapped out injectors to have them professionally cleaned.
    Its' pretty clear to me that fuel pressure has to drop as the car sits overnight. When you do a key on, that provide the fuel pump time to repressurize -- which cures the delay. Or, if it doesn't sit very long, it doesn't have time to lose pressure.
    I actually don't understand how pulling the fuel rail loose cause my particular issue. I tried a second set of injectors with no change. Plus, running fuel pressure is where it's supposed to be -- which implies I did no harm to the FPR. I did note the same poor condition of the vacuum line that drives the regulator. So, I installed new vacuum line from stuff sitting in my garage. (Did this before measuring FP).
    New viviton injectors seals were installed both times. The second time I took extra time to clean bungs in the manifold and rail.
    I don't smell gasoline in the morning -- and you'd think this would happen if the fuel was losing pressure externally. These days, I think most fuel systems hold fuel rail/lin pressure thru a check valve built into the fuel pump. Changing injectors shouldn't affect that.
  1. ...That's when the fight started!
    Last Post: 10/02/2010, 08:28 AM
  2. The Roof scoop project has started.
    By CoastieCosta567 in forum VX Modifications...
    Last Post: 10/01/2010, 11:52 PM
  3. Started the season off with a bang!
    Last Post: 02/28/2009, 09:48 PM
  4. '09 Dakar has started!
    Last Post: 01/10/2009, 05:08 AM
  5. Started the big Q today
    Last Post: 05/11/2008, 07:03 AM
