Results 31 to 45 of 59
Thread: Project ZU: Rear Tire Carrier
  1. #31
    Got any pics of the exterior of the hatch without the tire mounted? Curious to see what you did to mask the butchery that needed to be done.
    I'll take a picture this weekend for you & Ala5ka
    Jon- the rear door looks great, but im just curious, are you going to build some additional protection over that gas tank? it looks like it hangs down quite a bit more than factory because of the body lift.
    I realize with bigger tires, it will touch less often, and the OD of the tire is technically closer to the rear of the vehicle, but it just looks vulnerable?
    Its on my list.
    I've been waiting for Tom4bren's custom hitch to become available. The design is a perfect way to protect the gas tank.
    In addition, I want to raise the gas tank 2-3" so I have more rear ground clearance. It shouldn't be too difficult.
  2. #32
    knowing you, i figured you had something brewing, i was just curious if it was re-designing the brackets or a new skid plate....
    So many projects, so few days to Moab
  4. #34
    Quote Originally Posted by Ala5ka View Post
    Do you have a picture of the back with the tire off? How is the HiLift mounted as well?
    I posted a pic today of the rear door without the tire, it's in the first post.
  5. #35
    Jun 2008
    2001,black, vehicross 1353
    Looks alot better then the bulge imo. That rounded bulge is a little femmish, don't wanna say gay and offend anyone but the term really fits that female like curve on our vx's posterior. It's just not rugged enough looking. Plasma cutting it off and mounting that meaty tire back there is bada$$. Extremely awesome. I'm on the hunt for a back door to chop up!
    Milwaukee WI
  6. #36
    Quote Originally Posted by djvx View Post
    Contact our buddy Vic and drive down and get the Foxfire rear gate! He'd probably sell it separately.
    http://www.ebay.com/itm/250979098149...ht_1316wt_1187
  7. #37
    Jun 2008
    Thanks guys, I considered working on a second one with my old door & putting it for sale but the time (increased price) & size would be a major issue. I have smaller projects planned for the future & hope to offer those things for sale if there's interest.
    Tom, I looked into reinforcing the hinges but didn't have enough room behind them to add strength. If I start having issues, I'll weld the hinge to the door... or something
    Glue or adhere support shims onto the cladding so as you shut the door it slides up onto the shim supports. Then the door is held up by the hinges, the latch, and the shim supports. It aint goin anywhere.
  8. #38
    The bump stop I installed seems to be doing a good job supporting the door. I also installed a safety strap to the tire carrier just in case something really broke. I was a little nervous when I first installed the door that a "weak link" would show but now I'm confident the door will hold up.
  9. #39
    Jun 2008
    Im starting a thread looking for a back door.
  10. #40
    Did you read my post #36 and click on the link? There's one in Lake Villa, that's like what 2 hr drive tops?
  11. #41
    With the body lift you need to find a way to lift the gas tank...it really hangs down and is more noticeable without the hump.
  12. #42
    O/T, but how is a woman's curvy derriere a bad thing? I guess if you personify your VX as a man rather than a sexy lady perhaps...
    Just joshin' ya!
  13. #43
    Mar 2011
    1999, Astral
    Question? Do you ever think of your HiLift as a samurai sword? Because that's how I feel about it. Also thanks for the rear door pic, I've got some ideas for when I do this
  14. #44
    Late to the Party
    Its on my list.
    Here's a pic of Matt's Trooper from Indy4x for reference. With the skid plate off I should be able to cut the 2 inner mounts & weld the tank higher. Looks to be a fairly easy project & the result will look much better with a tucked gas tank. I also need to make a rear bumper plate to cover up the frame below the cladding.
  15. #45
    I was thinking red squirrel tail when I first put the hi-lift on because I had it mounted above the roof line & visible from the front. Samurai Sword... much cooler
  1. New Jet Ski Carrier!
    Last Post: 11/08/2014, 04:13 AM
  2. Rear Door Spare Tire Mount
    By tom4bren in forum VX Modifications...
    Last Post: 12/29/2011, 01:15 PM
  3. Roof rack spare tire carrier
    Last Post: 07/01/2010, 10:13 PM
  4. Replies: 1
    Last Post: 11/20/2006, 09:29 PM
  5. Rear Tire
    By surfindonesia in forum VX Talk...
    Last Post: 12/04/2003, 04:34 PM
