Results 16 to 30 of 59
Thread: Project ZU: Rear Tire Carrier
Threaded View
    I finally finished my spare tire carrier using a junked VX door I picked up over the summer. Over a year ago I had an idea to make a tubular spare tire carrier for the VX. The project was quickly ruined once I realized how funny it would look with the rear door bulge...which started the next project
    Goal: use a VX rear door to make a spare tire carrier (like Tom4bren, Marlin, & eblank) but remove the "bulge" & have the bumper wrap the tire.
    Last January I told Jack (PBkid) my plans at a VX meet & he told me "you don't want to do that"
    In July I sourced a junked VX for the back door & met Mdwyer in the process
    In September I cut the center of the door out and test fitted it.
    In October I welded 1"x1" square tubing into the door & found a trooper spare tire carrier from the junk yard.
    In November I welded in sheet metal without the "bulge" and began the long process of fiberglass/bodyfill work.
    In December I pulled the glass & cladding from my old door and installed them on the custom door.
    Overall I'm happy with the door. I finally don't need to worry about where to put the big spare tire
    And here we are:
    Test fitting the door
    I used a bump stop to take the weight off the latch. The bumper had to be cut for the tire to fit so I used sheet metal for the finish.
    I left some imperfections on the center of the door because I'll always have a tire back there. I also decided to make the cladding end under the tire rather than attempt to fit the cladding across the door.
    I kept this project pretty quiet until the end. There were several members following the build so for my next project I will post a thread and keep it updated with progress.
  1. New Jet Ski Carrier!
    Last Post: 11/08/2014, 03:13 AM
  2. Rear Door Spare Tire Mount
    By tom4bren in forum VX Modifications...
    Last Post: 12/29/2011, 12:15 PM
  3. Roof rack spare tire carrier
    Last Post: 07/01/2010, 09:13 PM
  4. Replies: 1
    Last Post: 11/20/2006, 08:29 PM
  5. Rear Tire
    By surfindonesia in forum VX Talk...
    Last Post: 12/04/2003, 03:34 PM
