This is a good thread to read. Nice to have this option in the back of my head if the transmission ever goes out.
 Super VXer
						Super VXer
Ya, now if someone would just do it for me. My garage isn't large enough to turn wrenches well in and none of my trusted shops wants to tackle it. Most citing it isn't high on their "want to to list" or "it's going to take to much of their time due to R&D". I respect both excuses.
 Super VXer
						Super VXer
						Over all it hasn't been that difficult. Some parts are time consuming like mating the cases together. I figure I will have spent around 40 +- hours doing the swap. A possible compromise would be to just have a shop pull out the auto and install the manual. From there it is fairly straight forward. Shouldn't be any R&D required once I finish the documentation. No fabrication or welding needed, I did have to drill 1 hole in a dust cover but that is it. I was concerned the Trooper shifter would be too tall but as it turns out fits perfect.
I will document the wiring needed to finish off the build here soon. Been under the weather the past couple days.
 Super VXer
						Super VXer
						Sorry to hear that Greg, hope you feel better!
 Super VXer
						Super VXer
						I've been sitting on my AR5 and respective flywheel for about a year. Now that some other things in my life are starting to settle a bit, I'm going to get this tackled in the early part of this year. This thread is a boon, so thanks!
IIRC, BigMeat said something about still needing to figure out the cruise control. I hope that will be addressed in this thread, as well.
Keep up the bodacious work!
 Super VXer
						Super VXer
						Good luck with your Vx trans swap you might want to look into a trooper with the manual trans has everything your looking for even a on/off button for the TOD system.
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						 Super VXer
						Super VXer
