Results 1 to 15 of 22
Thread: Engine smoking/coolant everywhere...
    Aug 2008
    Try wiggling the spindle that turns the water-pump mechanism. If it wiggles/woggles at the spindle as to indicate an out-of-balance rotation, then it likely indicates a faulty water-pump.
    If you don't plan on replacing the water-pump yourself; then you can re-fill the radiator and overflow res, and quickly limp the VX (while the engine is still cold from sitting overnight) to a nearby mechanic/shop for repair.
    Nov 2007
    1997 SILVER
    Good luck with checking the wobbly water pump spindle from the outside of the engine.
    The water pump drive is under the timing belt covers, so you have a lot of work to do to get to it.
    Stick with the gaskets, hoses, and o-rings that Mark and the others have mentioned. The water pump could not throw water up that high even if it exploded.
    PK
  1. Coolant leak! Help!!!
    By ron in forum VX Troubleshooting...
    Last Post: 04/25/2009, 01:56 PM
  2. Leaking coolant from bottom of engine
    By hnt4redoktober in forum VX Troubleshooting...
    Last Post: 03/13/2009, 01:59 PM
  3. Coolant leak ?
    Last Post: 02/26/2009, 09:34 AM
  4. Coolant temperature??
    By cascabel3 in forum VX Troubleshooting...
    Last Post: 08/26/2005, 03:34 PM
  5. Plugging off coolant.....
    By jayfotos in forum VX Modifications...
    Last Post: 03/30/2005, 12:00 PM
