So since I bought my vx this spring, the dome light hasn't worked with the drivers door. It goes on and turns off as it should with the passenger door, but does not react at all to the drivers door. It also works fine when you push it on and off. I replaced the switch that the door hits on the door frame and checked its ground but it made no difference. Anyone have any ideas or suggestions before I start chasing wires with a voltmeter?
