Results 1 to 4 of 4
Thread: Where is the PCM Fuse?
    Jan 2008
    2001,Yellow, VX, 0795
    Does anyone know the location of the PCM fuse on a 2001 VX? The shop manual instructs to check the 30A PCM fuse, but I checked the two fuse boxes, and could not see anything label as a PCM.
    Thanks for your help
    its most likely labeled ECU or ECM on the fuse box
    Jan 2008
    I looked at Main fuse box under the hood and there was only one fuse labeled ECM (EB-18) but it is a 40A fuse, the manual says to replace a 30A PCM fuse...was that a typo? What is the rating on yours?
    Thanks a lot for your reply...I am trying to solve an issue with the "Engine Fuse CB-3" constantly blowing. The shopmanual instructs to check the 15A engine fuse, the 30A PCM fuse and to check for short to ground in the PCM ignition and battery feed circuits...which I don't know where they are. The engine fuse blows the second I turn the key on...before the engine cranks.
    Jan 2008
    The shop manual I downloaded from this site was for model year 2000, did Isuzu go from a 30A to 40A ECU fuse on the 2001 VX models? I do have a 40A ECU fuse under the hood
  1. fuse box diagram
    Last Post: 11/27/2015, 09:18 PM
  2. fuse FL-1
    By patrick cooper in forum VX Troubleshooting...
    Last Post: 08/28/2013, 06:35 PM
  3. AC fuse keeps blowing out
    By TexVeX in forum VX Troubleshooting...
    Last Post: 10/12/2009, 06:39 AM
  4. fuse box under hood
    By patrick cooper in forum VX Talk...
    Last Post: 09/21/2009, 07:32 AM
  5. Fuse Box
    By Bantan in forum VX Talk...
    Last Post: 03/26/2003, 02:56 PM
