Results 1 to 15 of 24
Thread: Transmission/clutch problem -- VX bucks!
    Oct 2007
    99, Big Blue VX, 0344
    Wrench Transmission/clutch problem -- VX bucks!
    I wonder if anyone else has encountered the problem I'm having with my 1999 VX (approx 113,000 miles)? Sometimes, when accelerating rapidly from a standing start, especially if on a slight uphill grade, the transmission will appear to slip and then literally buck (rear wheels only as far as I can tell) when engaging. It may do this repeatedly when accelerating through 1st and 2nd. It may also do this on a bumpy road, for instance, when on a road that seems to have ridges on it every so often. I'm guessing a problem with the clutch pack but it is hard to tell how bad it may be. I can prevent it from occurring simply by accelerating more gradually.
    One transmission shop said $2500 to $3000 for a new "kit" without even getting into it. Has anyone else experienced this and, if so, how did you correct it? This is my second VX and I never had this problem with the first one. Thanks.
    Jul 2011
    2000 Proton Yellow #0586 CROSSCHECK
    I haven't had that problem, but a few months ago when I first got my VX, the tranny went out completely. I purchased a used transmisson from a member on here (Wisdom) and had it installed. Total was about $1300 to buy and have it put it at a local shop. Much cheaper and works great now! It was a much better option for me than to have it rebuilt for $3000-$5000 I was quoted. Ha.
    "Therefore we conclude that a man is justified by faith without the deeds of the law. -Romans 3:28
    Oct 2011
    1999, Black, VX, 9999
    I have a similiar problem but its a rare occurance. My front wheel drive is disabled so it has to be a wheel rear drive issue. I did have a hard, loud clink when it down shifted but changing trans filter, fluid improved that immediately. Let me know if you find a fix.
    Wrench
    The first thing I'd is check the fliud level/color...
    THEN decide what you need to do.
    Feb 2009
    1999,silver, 1516
    What you are describing sounds a lot like what mine does under hard acceleration. But when mine does this it's actually cycling power to the front wheels on and off rather quickly, like it thinks the back tires are slipping (that's not gonna happen) I can see the TOD bars flash full and back down over and over and feel the surging that coincides. I've heard other owners mention this after adding larger or more aggressive tires. I have 33 inch MT tires and that's when I noticed it starting. It hasn't bothered me enough to worry about fixing it. I don't often leave a stop under full throttle...
    To see if yours is doing what mine is, just watch the TOD graph and see if fills up when it surges.
    Quote Originally Posted by ColoradoVX View Post
    2001 Proton VX #0690
    It also sound vaguely like the transmission mode switch. When you change the transmission lever, do the lights on the dashboard follow it? Or do they flicker and show random things? After a few seconds of getting an invalid result from that sensor, it will silently go into a limp-home mode that causes shifts to be REALLY harsh, complete with CLANG!
    Apr 2011
    2001, Silver, Kaiser, 0304
    Are you sure its a tranny problem? I needed a new fuel pressure regulator (and fuel pump) when I encountered bucking as described here http://vehicross.info/forums/showthread.php?t=20261
    '01 Ebony #0939
    Jul 2009
    2000, white, ironman, 0699
    I'm having this bucking thing going on too. I'm hating it. I'm trying not do drive it so much right now for fear of doing permanent damage to something, like the transmission I guess. It's gotten worse over the last year.
    From 1st gear to 2nd gear, over 50% of the time, not always, my transmission will buck, buck, buck, buck, like a fast and hard chugging feeling, the whole car shakes, then shifting gets back to normal. Also, on occasion, when coming out of a right turn and giving it gas the engine will rev up, but not engage for some reason. Gotta be related, no?
    After searching and searching this website for a probable cause -- I ordered a mode selector switch and will try to replace it this week. Folks make it sound easy, and it looks it, only one screw -- but it looks tight under there too. The transmission lights on my dashboard are not randomly blinking, as others have mentioned with similar troubles.
    By the way, about a year ago, the best transmission shop in town advised me to not change my transmission fluid, not even one quart. The fluid was too old and new fluid may cause my transmission to give out, not go. Something about my transmission now needing the sludge to engage the gears, he said. He went on to say that GM transmissions usually give out at about 125,000 miles -- to drive it until it dies and then bring it in for a rebuild job.
    I have over 130,000 miles. Over the years I never changed the transmission fluid as often as I should have -- but don't think that's what causing this bucking thing.
    I'll let you know if a new mode selector switch helps. For less than $150 it's worth a shot. If it doesn't help, I'm going to take it in and have it looked at.
    H. Diaz / Austin, TX
    Jul 2009
    HELP, my gear shifter is stuck in "Park". After swapping out my mode selector switch with a new one, the button on the gear shifter will not depress. I can't move the shifter. The front end is up in the air about 1 foot using ramps I have. I can't get it down.
    Anyone have an idea what might have happened and how to fix this?
    Thanks in advance, H. Diaz
    2000, Ebony, VX, 0370
    Thanked: 12
    Try reading through this thread: http://www.vehicross.info/forums/sho...threadid=17994
    There is a solenoid that releases when you press the brake pedal that allows you to shift out of park. Yours may be boogered up, or maybe wasn't reconnected when you replaced the mode selector switch.
    2001 Proton VX #0662
    Mine isn't bucking but it does slip once in a while when shifting, usually from first to second I think. Someone told me that thing about not changing the fluid too because it will make the tranny more likely to go out than to fix it! I'm wondering if I should keep trying to ignore it or take it to the dealer or what! I love my VX and want it to stay perfect forever!
    Canadian VXer!
    2001,FOX FIRE RED MICA,0251
    Quote Originally Posted by mrtew View Post
    CHANGE UR FLUID AND FILTER,not changing the trans fluid is the craziest thing i have ever heard,I guess if the engine oil gits old n gummy we should just leave it alone and drive it till it dies too huh.lol
    Jul 2009
    ....update.... my transmission was 3 quarts low. I took it to a local transmission shop for a 2nd opinion. See story below. They topped it off with out charging me. Nice. For now, it's shifting normal again. Thank goodness.
    This was causing the symptoms I described above, bucking from 1 to 2, engine revving but not engaging and typical slipping.
    Hopefully no serious damage was done with 3 quarts low. This is the same shop who last year warned me about replacing old burnt fluid with new fluid. It could cause problems. Well now I have 3 new quarts so we'll see.
    So, where did my 3 quarts go? I don't think it's leaking. I have no spots on my driveway.
    Get this, a couple of weeks earlier I went to an authorized dealership in San Antonio, TX for diagnosis. They said I needed a new transmission and quoted me $7,000. A day later they lowered it to $6,000. And a day after that they had a used transmission for $3000 with about 130,000 miles on it, similar to the miles on mine. I paid $90 diagnosis fee and brought her home. For $90 the dealership didn't even bother to check my transmission fluid. Was this an attempt to rip me off? Maybe they think Vehicross owners will do anything to keep their beloved car rolling. A**holes.
    Quote Originally Posted by hxdiaz View Post
    OR...they drained 3 qts, knowing symptoms would worsen, & your tranny would eventually fail...
  1. 99 transmission problem
    By BethanyS in forum VX Troubleshooting...
    Last Post: 10/14/2013, 03:02 PM
  2. transmission problem
    By vulcan in forum VX Troubleshooting...
    Last Post: 09/21/2011, 07:12 AM
  3. transmission problem
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 05/16/2009, 05:28 PM
  4. Transmission Torque Converter Clutch Solenoid Issue
    By VehiGator in forum VX Troubleshooting...
    Last Post: 07/14/2006, 10:53 PM
  5. Transmission Problem 2
    By Freon VX in forum VX Troubleshooting...
    Last Post: 09/27/2003, 09:54 PM
