I wonder if anyone else has encountered the problem I'm having with my 1999 VX (approx 113,000 miles)? Sometimes, when accelerating rapidly from a standing start, especially if on a slight uphill grade, the transmission will appear to slip and then literally buck (rear wheels only as far as I can tell) when engaging. It may do this repeatedly when accelerating through 1st and 2nd. It may also do this on a bumpy road, for instance, when on a road that seems to have ridges on it every so often. I'm guessing a problem with the clutch pack but it is hard to tell how bad it may be. I can prevent it from occurring simply by accelerating more gradually.
One transmission shop said $2500 to $3000 for a new "kit" without even getting into it. Has anyone else experienced this and, if so, how did you correct it? This is my second VX and I never had this problem with the first one. Thanks.
