Results 1 to 15 of 17
Thread: Surface rust and grime removal??
    Looking for recommendations for a chemical product that will remove surface rust and grease/grime from metal. Looking for something available to the general public, doesn't require special equipment and is relatively safe. You know, something that can be brushed/sprayed on and hosed off. This will be used on an axle housing by the way.
    Naval Jelly works just fine, it can be washed off.
    Here's the MSDS
    http://www.henkelcamsds.com/pdf/2351...6_01_80277.pdf
    Should be pretty available. Lowes and Ace both list the Loctite Brand
    Feb 2010
    2001,Kaiser,1130
    Naval Jelly is Phosphoric Acid in a gel. It all really depends on the metal. You may not be happy with the results. The best way to get rid of the rust entirely will be physical abrasion like sanding or sand-blasting. Some stores sell a rust "converter" which stabilizes the iron oxide to a paintable surface.
    I've tried Naval Jelly on old Alfa Romeo rotor/dust covers and found that even after 10s of minutes it barely removed any rust from the part. Sanding was the only way to fix that. I believe the porosity of the metal is very important to the various acidic treatments.
    Feb 2009
    2001 Proton Yellow VX 0938
    I have found that naval jelly requires a good amount of elbow grease with a bristle brush or more to get anything more than very light rust off.
    On this topic, what does the collected wisdom recommend for smaller pieces, like cladding screws and things, that are starting to get a bit of rust, or maybe have more than a bit? I seem to recall someone soaking their small bits and pieces overnight in a chemical before applying a rust stop type coating and paint. Might be useful for Tri's application as well.
    Feb 2010
    2001,Kaiser,1130
    That overnight chemical would probably be a liquid Phosphoric Acid. If you aren't in a hurry:
    http://www.youtube.com/watch?v=b-_z4tinnXk
    The rust stop coating would be difficult to apply onto the bolts and screws. It may be best to get new ones or get alloy or a non rusting variety of hardware.
    Quote Originally Posted by Osteomata View Post
    When I was restoring my Cobra, every nut, bolt and bracket that wasn't new was treated to cleaning with a wire brush on my bench grinder. Some took a little more work, but they all looked like new by the time I was done. A few larger pieces were then sprayed with Nyalic coating from the Eastwood Company. A quick Google search seems to show that they no longer carry Nyalic spray, but they should have something equivalent. For removing grease I usually use Bleche-Wite or Simple Green. I have used Bleche-Wite on my tires for decades.
    Gregg
    2001 Proton Yellow #1379
    Here ya go Billy...
    http://www.vehicross.info/forums/sho...t=rust+remover
    But since it's an axle housing, I'd use a wire wheel on a mini grinder.
    I was recently told to try CLR. I am going to give it a go on the Impulse coolant hard lines. A lot of built up rust in the lines and they need to be cleaned out...parts discontinued.
    Sounds like a quick once over with a media blaster would be ideal...
    ...probably OK $'s wise if you take into account Chems/grind wheels/time etc.
    Time is the one thing I have!
    2001, Ebony Black, 1153
    I got a spray gel from Pepboys paint department and it is awesome. Once I over sprayed on some paint and the next day it scraped off down to bare metal and I just put some touch up paint on it. It says that it removes rust and preps for paint and it has done just that for me multiple times, works perfect on old ball joints, and axle housing. I don't remember the name I am not at the house right now, but it is in a white bottle with a squeeze trigger on it.
    That sounds like what I am looking for Ryan. If you remember the name let me know. If not I will just search the shelves.
    Once it is stripped and cleaned up I am going to tear it down and will paint it with spray-on truck bed liner.
    Permatex - Rust Dissolver Gel - item# 82138
    It has worked good for me.
    Ingredients: phosphoric acid, polysaccharide, 2-propanol, surfactant, silicon dioxide, amorphous
    Aug 2008
    Here's the Permatex product "link":
    http://www.permatex.com/products/Aut...solver_Gel.htm
    Thanks Ryan!
  1. Check your roof racks for surface rust.
    By Ebenezr in forum Chit-Chat ...
    Last Post: 01/03/2011, 11:41 PM
  2. Evapo-Rust Mini Review - Clean rust off of small parts
    By twistedsymphony in forum General Tips...
    Last Post: 09/17/2009, 07:27 AM
  3. Rust
    By kimonh in forum VX Talk...
    Last Post: 05/03/2006, 01:03 PM
  4. Must stop...rust....help..
    By Whaleboy in forum VX Troubleshooting...
    Last Post: 07/31/2003, 07:50 PM
