Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: High Idle suddenly =/
    Jun 2007
    2001, Proton
    I had a similar sound
    wasn't high revs but low oil. Made it sound like high reving. Now when I hear it I just change the oil. Hey why add a quart to dirty oil when its about due anyhow?
    Carter Pewterschmidt
    Aug 2005
    1999, silver, 0887
    Nice looking engine room, KAT!
    Nov 2010
    xxxxxxxxxxx
    Intake Manifold Gaskets.... that's what mine was
    '99, White, Iron-Man (0109)
    Intake gaskets for me too. Thought I'd have that code FOREVER. Also, cleaned the IAC motor & MAS sensor thoroughly. Light out. Idle restored. CEL has stayed off. Had CEL from just over 100k miles to around 200k miles. 213k now. All better.
    Jul 2011
    2000 Proton Yellow #0586 CROSSCHECK
    Problem solved. I bought a can of mass air flow cleaner, a can of carb cleaner, and a new PCV valve. Tore open my throttle body and took er inside and scrubbed her down good with a tooth brush and carb cleaner. She was gunked up like crazy. Way worse than I would have imagined. I also took off my throttle position sensor and idle air control sensor and cleaned those out really well. It was nasty all up in the IAC's parts. Way totally disgusting. Worst the the butterfly and throttle body itself. I was idling up to 2500 RPM in neutral and could idle down the road at 25 MPH, no foot on the gas. She is idling lower than ever now. In park she is at about 800 RPM and drops to around 500-600 when in gear I think. I wonder if I'll get better fuel economy now......? Throttle response should definitely be better though!
    "Therefore we conclude that a man is justified by faith without the deeds of the law. -Romans 3:28
    2000, Kaiser, #0016
    Good job Breezy! You covered all the bases, did it yourself and did not spend a lot of $$$ trying. Sounds like you nailed it, hope it did!
    Quote Originally Posted by Breezy View Post
    Jul 2011
    Yeah, I got a little nervous. After I replaced the PCV valve it started my check engine light came on for the first time ever. But I had autozone read the code and it said "intake air temp" sensor, which I had moved around earlier. I pulled it out, stuck it back in and turned it upright and it worked fine and my check engine light went right off. What a relief. I was really scared there for a moment lol. I think today I might see about getting a synthetic swap for standard oil change somewhere. It's due, and I have 2000 miles of driving to do over Thanksgiving....Rear speaker replacement may also be something on the list of things for today. 12 hours in a car with blown rear speakers may become irritating...
  1. fan noise & high idle
    By Baldwin in forum VX Talk...
    Last Post: 11/29/2012, 10:28 PM
  2. High idle/ high power steering pressure?
    Last Post: 09/22/2007, 04:21 PM
  3. High idle question
    Last Post: 01/18/2007, 06:14 PM
  4. High/Low Idle at start up
    Last Post: 03/19/2006, 07:20 AM
  5. RPM to high at idle
    By ThunderChicken in forum VX Troubleshooting...
    Last Post: 09/23/2004, 12:09 PM
