"Like"
 Super VXer
						Super VXer
						Do you know when the cup holders/console will be available for sale by chance or a rough timeline??
Rolling around the pacific northwest ...
 Super VXer
						Super VXer
						I am a buyer and will prob find some more takers if you'll be willing to send to Russia, Ron
Vodka... Connecting people
Needs more COW BELL, Um I mean buttons. JK I would pick one up just to give it a try. If it didn't work out the no cup holder could always go back.
Always wanted a replacement for the two pieces ever since I saw some pencil sketches for the the shifter and the brake areas on the forum a few years ago. (not sure if those were your sketches) I really like your work, and would likely buy it as I have your skids already.
I will admit (Not trying to come across as a complete a-hole) however I'd like to see something with a little more aggressive styling, ie more ergonomic/rounded -- less conventional from the 90s era of the VX. Maybe tilt the switches at a 45 angle, round the piece more. Isuzu really stopped at the styling of the controls compared to the rest of the vehicle. Given the quality of your work, I think you could really fix their mistake.
On a similar note, I still plan on taking out the ashtray assembly and building a "power area" with 3x cig plugs and a 110V plug to make up for the lack of those (and the fact I don't need an ashtray except to hold screws when I take stuff apart).
-Wekilled
douglaswekell(at)gmail.com
I will buy one.
 Super VXer
						Super VXer
						i want one,i hate the center console design,and was thinking of trying to make a custom console and put a 7 inch touch screen dvd deck where the ashtray cig lighter is.
this would be easier.would love the shifter piece too.
i'm in
 Super VXer
						Super VXer
						I had the same idea --> removed ashtray/6 CD changer & relocated the cig lighter to the center console. I installed a back up camera screen in place of everything removed. It works but I would build an assembly to angle the screen up if I were to do it again.
I also installed a CB radio into the center console (bad idea) & would love to get this cup holder console to fix that mistake.
Keep us updated on the cup holders when you get a chance Ron.
Even when you unscrew/install a new piece, it's not permanent. Glued isn't even permanent. (Think about tiled floors that get replaced.)
I understand many people aren't inclinded to grab a screwdriver and do installation. So, this point about a layover piece is valid. It might get more sales (if layover). But, if the point is to get a factory-like appearance with integral location of switches, I think the OP is on-track and should ignore votes for a drop-in part. Console installations are, after all, very simple.
I like the stacked location of the glass-holders. Making them sufficiently deep to avoid spills is critical. As is, the OEM bottom, shallow tray isn't good for anything. Cups, change, nor a phone will stay in place w/o sliding off under a seat. IMO, the factory center console is laughable.
Whether it be an aftermarket piece, or a suggestion from other automobile, the need for a better-designed center console is huge for these vehicles. On the switches issue, reusing factory switches (in their original harnesses), is best. OTOH, delivering a new piece with plug-in 2/3-gang switch plate also has merit. Consider a smaller triple-gang setup if you're having trouble with switch placing.
I vote for continued effort on this project. And, I'm curious how the plastic will be molded/formed. Does the OP have equipment necessary to do injection molding?
 'Zoid
						'Zoid
						I'm down for one as well, given all of the buttons will be accessable!
 Super VXer
						Super VXer
						Add peltier plates for your heating & cooling pleasure!
Sorry been out of the loop. Just taken a real big project that's keeping me busy at the moment.
I've actually have taken a different turn for the design. Still a 2-cup holder deal. But, a bit more organic than the current utilitarian CAD design you see. I'm in the process of building the mock-up prototype for fitting and clearance issues. It's still in its early stages. But, I'll post pics of progress when I have the 'look' closer to what I want. rudy
www.aftershockproducts.com
 Super VXer
						Super VXer
						I would feel really good about a replacement part that held a couple of oversize cups (think Starbucks thermals), fit in with the rest of the trim in terms of color and surface texture, didn't stand out too much in terms of design (whereas terms like "organic" and "slanted" indicate otherwise), and perhaps added a switch blank or two to the existing sideview defroster and blank.
In other words, "fix it."
-V
-VI VX VNIVERSVM VIVVS VICI-
