Actually, you can wire a ON button downstream of the lock cylinder or add a remote starter, then use a dremel to CUT the key so that only the shaft of the key is inside the lock cylinder, and so it can never be removed OR used to turn. Then put a JB weld cap over the thing, and you'll "remove" the key entirely. =)
