Results 1 to 15 of 18
Thread: what axle part is this?
    1999 silver 1346
    what name is the part is the one circled .its has to do with the front drivers side axle. the mechanic said the busshing in the cirlle part is worn out and it is not listed in the parts so i think i need that piece. and he cant get it .
    thanks
    That's known as the "diff bracket" to most of us but it may have a more official name. I have a spare bracket you can buy off me if you need one. PM me if you're interested, I only have one side so I would need to confirm if its the drivers side first.
    1999 silver 1346
    let me ask you the mechanic said when he took the screw out the rubber piece came out with it. is the rubber a separate part or is it permanently attached to that bracket? how much do you want for that part
    thanks adam
    Sorry for the double post... the site is acting laggy for me.
    The bushing is attached to the bracket, there's a metal sleeve that the bolt goes through & the bolt can fuse to the sleeve causing it to destroy the bushing when the bolt is turned. Same thing happen to me.
    $30 for the bracket but first I'll check it later today to see if its the correct side.
    1999 silver 1346
    thanks let me know
    Have you checked to see if the bushing is available through Merlin? Probably only be $15 or so.
    '99
    It's called an axle case bracket. The entire assembly is part# 8-97131-941-1. Go to My Isuzu Parts and enter that part# to see all the small parts that available separately. The rubber bushings, # 8-97018-240-0, are cheap and available from your local Honda dealer. Your mechanic could probably have them tomorrow, if they get parts deliveries on Saturday.
    http://www.myisuzuparts.com
    Mark
    1999 silver 1346
    Quote Originally Posted by deermagnet View Post
    Mark
    honda? that site only has isuzu cars. what honda car is it? the passport? and would it be the same part number?
    thanks
    also the mechanic told me it is safe to drive with the bushing worn out Isuzu that true?
    '99
    The Honda Passport is an Isuzu Rodeo. Our VX has LOTS of Rodeo parts, so they can all be purchased at any Honda dealer. Just walk up to the Honda parts counter and give him the Isuzu part number. It's the same part number Honda uses.
    Dude looks on his computer and says "we don't stock Passport parts anymore, let me check on availability at the Honda parts warehouse over in NJ". It just takes a minute to get connected. "It's in stock, I can have it here tomorrow morning by 11:00". You say, "great, get me two of those bushings", and pay for them then.
    You return the next morning and pick them up on your way to your mechanic.
    Done.
    Mark
    1999 silver 1346
    Done.
    Mark
    what number did you call that said they can get the part tomorrow in new jersey. all the dealers in brooklyn said it won't be here till wednesday
    1999 silver 1346
    also do you need a press machine to put that part in?
    I didn't know you could replace the bushing, you should look into that option zadam.
    ...or I do have the bracket for the driverside
    Pretty much all bushings should be replacable since they are a "wearable" part.
    Good to know, I have a bad one that I've been limping along and ill try to fix it next time the axle is dropped. The bushings seem like they're clued in and that's why I was thinking they were non serviceable. Maybe just a really tight fit
  1. CV Axle replacement
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 04/14/2014, 04:32 PM
  2. Need Help... CV/axle question
    Last Post: 11/29/2012, 10:28 AM
  3. cv axle replacement
    By ramathorn in forum VX Troubleshooting...
    Last Post: 09/25/2012, 08:20 AM
  4. Why is this on the axle???
    By VXorado in forum VX Troubleshooting...
    Last Post: 11/11/2011, 12:51 PM
