Results 1 to 7 of 7
Thread: TOD Troubles (Video)
    Oct 2011
    99, Black, 1234
    I've also got some issues with the TOD system.
    In dry conditions while driving the TOD will throw a lot of power at the front wheels even when driving fairly passively. This seems to happen the most between 30-50mph. It makes the ride very jerky and there is an audible whump-whump-whump (turn up your speakers to hear it) when it occurs.
    http://www.youtube.com/watch?v=wS3co65cm-c
    The TOD check light does not come on, but the light does appear to be working (lights up during the self-diagnostic check at startup)
    What should we be looking at first? Sensors? Connections? Tire pressure on all 4 wheels is equal and the 4 tires are the stock size and of the same make and brand.
    Any help with this is hugely appreciated.
    Thanks!
    Eric
    Oct 2011
    99, Black, 1234
    Thanks! I've changed the setting it should be viewable now.
    Aug 2010
    01 Foxfire Red Mica VX 0441
    very odd! i don't recall reading anything about this on the forum.
    2001 VX
    Mods
    2008 HUMMER H3
    '99
    As always with TOD, start with the tires. Are they all the same make and model with the same amount of wear and all at the same pressure?
    http://www.vehicross.info/forums/showthread.php?t=1740
    Search for other threads on this same issue.
    Mark
    Oct 2011
    99, Black, 1234
    Quote Originally Posted by deermagnet View Post
    Mark
    I just double checked the tires and one of the rears is the same size but a different make/model. Should I replace all 4 tires as a first step? That seems a bit drastic but if it's the best thing to clear the issue that may be just what I do.
    Edit: I'm going to try swapping the newer tires (left rear) to the front and see if that causes any change. I'll post back here with results.
    '99
    Put that odd one on the front and see if there's any change in the TOD behavior. Our odd size donut spare is always supposed to be used on the front only to avoid TOD issues.
    Mark
    Oct 2011
    99, Black, 1234
    Yep it was the odd tire. Thanks deermagnet! Problem solved.
  1. Soon to be VX owner, looking for troubles?
    By Grif in forum VX Troubleshooting...
    Last Post: 08/03/2009, 03:11 PM
  2. engine troubles
    By Hol_VX in forum VX Troubleshooting...
    Last Post: 05/27/2009, 10:46 AM
  3. Big Troubles With My Vx
    By GRIFTERNYC in forum VX Troubleshooting...
    Last Post: 08/02/2007, 06:29 PM
  4. XM wiring troubles!!
    By Dallas4u in forum VX Talk...
    Last Post: 03/02/2004, 04:07 PM
  5. Boarzheads troubles
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 10/17/2003, 08:43 AM
