Results 1 to 15 of 29
Thread: Damn Oil!!
    Feb 2010
    99 silver vx 1144
    Damn Oil!!
    So replaced old valve cover gaskets because they were leaking. Helped with oil consumption but..... I always replace pcv valve when changing oil and when replaced the manifold gasket common body was full of it! The tube from the pcv to the intake was caked as well. Cleaned out the tubing and the manifold and put in another new pcv valve. Ran for two weeks and tube and intake were once again caked with oil. Is there anything else that could be causing raised crankcase pressure causing massive amount of oil to be pushed up into intake? Any thoughts??
    Mar 2006
    2001 FOXFIRE 0579
    Is it oil only, or isthere any coolant mixed with it?
    Feb 2010
    2001,Kaiser,1130
    You could consider replacing the PCV valve with a breather, eliminating the flow of oil into the intake. We don't know if oil comes out of the breather, however. Search this site for a more in depth look at pcv replacments, breathers, and catch cans (which you can use to fiter the oil before it reaches the intake.
    Nov 2007
    1997 SILVER
    With your engine idling, slowly remove your oil filler cap to check if there is excessive piston blowby.
    If oil is being thrown out = bad news.
    If it appears ok, just hold your hand over the hole for 30 seconds.
    If your hand is oily, you have some blowby, but probably not excessive.
    If the pressure pushes you hand off - run.
    PK
    Feb 2010
    99 silver vx 1144
    Topped off oil started up and pulled oil cap placed piece of paper over and pushed down with my hand. Not even so much as a drop of oil. Any other ideas???
    Jul 2009
    Yes, a stickey ring. At idle the ring conforms just fine to the cylinder walls. At higher rpm the ring cannot move in the lands fast enough to seal against compression, resulting in blowby, hence your mess...You could try a flushing agent such as Sea Foam in your crankcase and hope for the best, otherwise a rebuild may be in your future. Sorry.
    Vixer Fixer
    '01 Ebony #0939
    If it's blowby though, isn't the only way that oil could get back up into the intake is if it went through the PCV system? No excess pressure at the oil filler cap would seem to indicate that it's not blowby, although if it was only checked at idle the higher rpm condition described wouldn't have been addressed.
    For whatever reason, the PCV systems on individual VX's seem to just be hit or miss as to whether they function correctly. A simple breather filter to replace the PCV valve eliminates even the chance of what's being described as happening though.
    If a VX suffers from oil usage because of a problem with the piston rings, oil usage is going to occur anyway, regardless of whether a PCV system is even in place.
    Nov 2007
    1997 SILVER
    Scott, you are correct. A sticking ring might need a higher load than idle for it to play up. Possibly even more load than just revving the engine while stationary, so it is hard to test that one.
    The Sea Foam treatment could work.
    Quote Originally Posted by Y33TREKker View Post
    Trekky, IIRC there are 3 rings on our pistons.
    The top ring seals compression in the cylinders.
    The bottom ring controls oil on the cylinder walls.
    The middle ring is multipurpose - it does a bit of each.
    So, it is possible to have excessive blowby without being an oil burner, and vice-versa.
    PK
    Wrench
    PK
    X a factor of 2...
    I've gutted my PCV system, & it now flows freely into a catch can, which is vented into the air box, with zero reduction in oil consumption.
    Sep 2010
    2000,Ebony,VEC,0013
    X a factor of 2...
    This is an interesting idea Dub. I thoughtof running my pcv down into a canning jar with some kind of filter and then back out again to the intake. I dea being the oil would be filtered out and fill the jar.
    '01 Ebony #0939
    PK
    Trekky?
    Anyway...
    I was just going by your original post, and not the additional things you've now brought up. If you guys want to have yet another discussion regarding the various trains of thought regarding oil consumption in VX's, have at it.
    But as I said, even if there is blowby, it still has to go through the PCV system for oil to get to the intake, which is what we're trying to figure out for p_justin.
    Jul 2009
    Trekky?
    Anyway...
    Further discussion? Don't mind if I do, thanks!
    Positive Crankcase Ventilation is exactly that, it allows for the ever-changing volume of air in the crankcase to be expelled and subequently replaced as the volume changes due to the reciprocating pistons in their bores. If you introduce an oil mist into that atmosphere, either due to oil being blown by the pistons rings or too much oil in the sump being contacted by the crank journals, that oil will find it's way out of the pcv system along with the air. A small amount of oil mist is normal, it is when it becomes excessive that you have the problem described...ultimately, it is the function of the pcv valve to regulate or control the volume of air entering or leaving the crankcase, not to separate oil from that air. Provided all internal baffles are in place to impede the flow of normal oil mist, a catch can is not required.
    Hope that helps!
    Feb 2010
    99 silver vx 1144
    Running sea foam through crankcase now will do upper intake tomorrow with oil change should have a hundred miles by then with sea foam to run through thuroghly through the engine. L dub how did you Jerry rig up you catch can setup any pics. Will probably do this anyways afterwards. Also is there any chance that a plugged up muffler raising the back pressure could effect this situation??
    Wrench
    Quote Originally Posted by p_justin13 View Post
    As requested: http://www.vehicross.info/forums/sho...t=breathe+suzy
    Jul 2009
    That three dollar part is VERY important indeed! Without it, excess pressure can build in the crankcase and blow oil out through the path of least resistance say, for example, the dipstick tube or the seals. Leaving the crankcase to vent directly to the atmosphere adds to pollution and that is why it is an integral part of the pollution control system. Years ago, it wasn't mandated and therefore didn't exist. The oil filler cap was usually vented and that allowed crankcase pressure to equalize with atmospheric pressure. That little part has been the cause of countless problems and engine failures, I guess that counts as a BIG problem!! When that part clogs, that's when the excess pressure problems begin. Now, the blowby problem is not a pcv valve problem, but it causes pcv problems; namely a clogged valve or messy residue within the intake system. That blowby is caused by excessive compression leakdown past the pistons compression rings allowing oil on the cyclinder walls typically controlled by the wiper rings to be blown into the crankcase as an air/oil mist. That mist is then expelled out of the pcv system through the pcv valve!
    Hope that helps explain things a bit better...
  1. That damn rectangle
    By ipd in forum VX Troubleshooting...
    Last Post: 05/20/2016, 05:50 AM
  2. Damn speakers!!!
    By p_justin13 in forum VX Talk...
    Last Post: 05/21/2011, 11:51 AM
  3. Damn you US guys make things big
    By VX-157 in forum VX Talk...
    Last Post: 06/25/2009, 06:55 PM
