Results 1 to 10 of 10
Thread: Transfer Case Problems! 4WD
    Oct 2011
    01, Silver, VX
    Can someone help me out. I'm a new member. 01 VX.
    My TOD lights up off and on and I hear a chain sound coming from the transfer case area. 4WD just knocks and grinds. Its basically obsolete now. Can someone explain in detail on send me some links to finding a transfer case and installing it myself??
    Jul 2009
    That is not the way to start off a beautiful relationship with your VX. The transfer case sounds like it's toast, that's not to say that it's not rebuildable though. May be cheaper then replacing, especially if it's just a broken chain with no collateral damage...Fingers crossed!!
    Vixer Fixer
    Jul 2009
    Oh, and welcome to the forum, wish it were under different circumstances!
    Aug 2008
    I'd take it to a reputable tranny shop that specializes in 4WD's and see what they say. It could be something simple or something drastic. Just my 2-cents.
    Are you sure its the transfer case? The transfer case is hard to break but the front axle & CVs are more problematic.
    You should be able to source a new transfer case from another TOD equiped Isuzu with the same auto tranny. You may get a different low range as many models came with a 2:1 low range rather than the 2.48:1 ratio we have in the VX... or you could upgrade to a 3:1 transfer case from Indy4x which would be a nice upgrade for trails (if you're into that). A new transfer case should be pretty easy to install with a tranny jack & some sockets. Sorry no links to new transfers cases... thats your job .
    Okay here is a link, a simple search found this transfer case for sale on the site:
    http://www.vehicross.info/forums/sho...=transfer+case
    I would PM the poster for availablity.
    Oct 2011
    01, Silver, VX
    Is there only 1 model VX in 2001? I would be interested in upgrading to the Indy4X transfer case is the price isn't outrageous.
    Quote Originally Posted by fultonix View Post
    There is only one model of US VX from 99-01, they only changed the climate control & wheels in 00-01.
    The "Ironman" edition was mostly cosmetic, with better speakers, & the JDM had limited edition paint colors available.
    Unless you're into 4 wheeling, it isn't worth the upgrade. the 3:1 transfer case give you better crawl ratio.
    Example:
    VX stock:
    2.48(transfer case) x 2.86 (transmission) x 4.30 (axle) = 30.5 crawl ratio
    Lower transfer case gears:
    3.07(transfer case) x 2.86 (transmission) x 4.30 (axle) = 37.75 crawl ratio
    I'm pretty sure the T-case indy has will fit out VXs but its probably not worth the $$. Its a much bigger upgrade for Troopers with a 2:1 T-case. Price is $999.00
    If you just want a replacement, I would look at junk yards and search for the transmission because they are usually paired with the T-case.
    www.car-part.com
    Oct 2011
    01, Silver, VX
    so 99-01 VX have the same transfer cases? Besides the Ironman VX
  1. Transfer case #'s
    By simonsayz1 in forum VX Talk...
    Last Post: 01/29/2015, 01:01 PM
  2. Transfer Case 4Hi blew up :-(
    Last Post: 10/30/2013, 09:04 AM
  3. what transfer case and trans do i get
    Last Post: 11/04/2012, 11:44 AM
  4. 2WD transfer case?
    By So-CalVX in forum VX Talk...
    Last Post: 03/03/2008, 09:40 PM
  5. Transfer Case
    By yal^ in forum VX Troubleshooting...
    Last Post: 04/16/2005, 10:12 PM
