Been doing a lot of maintenance on my VX lately.. in the past month I have..
Replaced rear pads and rotors
Replaced front pads rotors wheel bearings, repack etc
Dropped trans pan, replaced filter and gasket (was leaking)
Rear diff drain and fill
replaced 5 channel amp (old one started overheating)
re-wired air horn for faster response
only major project i have left is timing belt/water pump etc and i should be good for a while. shes still running strong at 122k
one huge annoyance i have been dealing with is my rear door rattles like crazy! every time i hit a bump it sounds like i have a box full of hammers behind the seats. any tips on how to get it to close a little tighter? i have moved the latch a couple of times sort of randomly and it will help for a day then come right back. Is there a secret to setting the door properly so that it doesnt move after 20 miles?
