Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: CEL p0440 back on after gas cap replacement
  1. #16
    Cool 2cule
    Quote Originally Posted by nocturnalVX View Post
    Here is that thread we we talking about last night. I hope it helps getting Suzie better.
    Oh, and it turns out it is not a thingamabob OR a doohickey... it's a whatzitznutz. FYI
    Thanx Gill...U Da Dood...
  2. #17
    I think that 'whatzitznutz' is called the purge valve solenoid.
    The little research I did though indicates that it could still be (in order of likelihood):
    non-OEM gas cap
    Cracked evap canister
    split hose or leaky connection
    wiring harness or bad connection
    I still get the P0442 code on the Amigo regularly (but only when the fuel drops below 1/2 tank). I'm running an aftermarket gas cap but should probably switch back to the OEM since the replacement didn't fix the problem.
    The US.RV shop manual has pages & pages on the subject. It just hasn't bothered me enough to try & chase down that gremlin yet.
  3. #18
    Wrench
    non-OEM gas cap
    My Amigo has had the ck engine light (maybe it's a Calvin Klein sublim ad) on since about 1 day after I brought it home from the used car lot where I found her. Had the code read, & same-same.
    Pulled tha ol' switcheroo VX-Amigo re: gas cap...no change...
    The only thing that makes the light go off for any appreciable amount of time is -15 degF & lower. Mebbe that's just too dam cold for tha light...to emit.....
    But that kajigger what Gill wuz talk'n about sounds like a promising next step...
  4. #19
    01, LineX tan/black, 1055
    Mine has been throwing p0440 for almost 6 years, about once a week or so. I just reset it with the ol scangage and not worry about it. Every once in a while I get the 441, which I believe is in the same category.
    2001, Proton Yellow, #0580
    I've been getting the C0441 also for about a year - tried all the obvious steps (replacing gas cap, etc). Goes off after a fill-up then comes back on at about half a tank. I just wait for it to go off to get the yearly emission sticker. It's irritating not to be able to figure out how to get rid of it completely.
    -- John
  6. #21
    Mebbe I missed the post or sump'n. What year did you get? Does it have the 3.2L? Stick or Auto?
    Mine's a '99 with the 3.2L 5spd. Previous owner upgraded to leather interior, added the temp/compass cluster on the ceiling & added the stock cruise control from a donor. It has the hard top but I need to get a rag top for it for summer use (I'd also like to get the hard top LineX'd since it's faded - cheap option for me now since Boy is working at LineX this summer & gets it done for cost of materials). I put on a 3" lift but haven't upgraded the tires yet so it's kinda funny lookin at the moment.
  1. CHECK ENGINE light - code P0440
    By Yefim in forum VX Troubleshooting...
    Last Post: 03/07/2013, 05:54 PM
  2. OEM P0440 troublecode
    By nairbnuapak in forum VX Troubleshooting...
    Last Post: 01/31/2013, 03:50 PM
  3. Shock Replacement - Bilstein direct replacement?
    By Feidhlim in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/11/2009, 06:17 AM
  4. Baby Got Back. (New back, I mean.)
    By PHO2GR4 in forum VX Talk...
    Last Post: 02/09/2008, 07:40 PM
  5. Check Engine P0440
    By Inaba in forum VX Troubleshooting...
    Last Post: 05/16/2003, 10:46 AM
