 Originally Posted by
Slideways
				Not sight unseen. Was a friend of mines who has been overseas. I've actually driven it a couple years ago and it ran great. Her parents just left it in the yard and never touched it.
And her parents were actually nice enough to at least turn it over for her on occasion.... *facepalm*
Ya, I would elbow-drop them too.
Sitting out in the yard, I would be worried about A LOT. What has been chewed on by vermin. What fluid lines, vacuum lines, and/or tires have dry-rot. Is there any rust factor. Depending on temps, moisture, and humidity, I would even be curious as to any mechanical seizing.
You definitely  "MAY" have your work cut out for you. Even if you get it turned over, I would continue my 85 points check and change process. I am iffy, but I wish you luck. (I always expect the worse so that when nothing or little goes wrong, I am pleasantly surprised)
