I just installed a 3" body lift yesterday & thought it would be a good opportunity to show how much lift you can get out of a VX without major modification.
First off, sorry for the dirty VX. I did some test driving on a bumpy dirt road to check for noises & rubbing.
3" body lift + 4" suspension lift (IFS has no downtravel left) with 35x12.5x15 MTR tires.
7" of lift makes the 35s look small-ish, I'm pretty sure Boarzhead has a similar amount of lift to fit 37s.
I took pics after the bodylift to show the amount of "out of the box" lift you can get but I don't recommend running your VX with 4" suspension lift. The IFS with no down travel makes the ride extemely rough & the increased angle will wear out ball joints and CVs quickly. To fit 35" tires, you need about 4-5" lift without extreme wheel well cutting. IMO adjusting the vehicle's height with a body lift & suspension lift is a best way to go.
Today I adjusted the suspension lift down 2", which should give me 5" of total lift. I have a 2" diff drop so the CVs are completely level. Now the rear axle has a reduced pinon angle that should stop u-joint vibration I was getting with the 4" of lift.
The 35" tires fit nicely & I have the same ride quality that I had with 32" tires. I left a little rake to anticipate some extra weight in the back.
The end result with 5" total lift:
).... in Moab in 2009 my flag pole on my Yakima BASKETwas sagging, and the metal connector kept coming unthreaded....I ask Jon for some help, after trying to jump up at it to fix it...since it's about 9" above the roofline....Jon walks over and tightens it all up, and it was basically at his arm level!
Sure appreciated his height that day!
