Results 31 to 45 of 61
Thread: 7 inches of "out of the box" lift
Threaded View
    I just installed a 3" body lift yesterday & thought it would be a good opportunity to show how much lift you can get out of a VX without major modification.
    First off, sorry for the dirty VX. I did some test driving on a bumpy dirt road to check for noises & rubbing.
    3" body lift + 4" suspension lift (IFS has no downtravel left) with 35x12.5x15 MTR tires.
    7" of lift makes the 35s look small-ish, I'm pretty sure Boarzhead has a similar amount of lift to fit 37s.
    I took pics after the bodylift to show the amount of "out of the box" lift you can get but I don't recommend running your VX with 4" suspension lift. The IFS with no down travel makes the ride extemely rough & the increased angle will wear out ball joints and CVs quickly. To fit 35" tires, you need about 4-5" lift without extreme wheel well cutting. IMO adjusting the vehicle's height with a body lift & suspension lift is a best way to go.
    Today I adjusted the suspension lift down 2", which should give me 5" of total lift. I have a 2" diff drop so the CVs are completely level. Now the rear axle has a reduced pinon angle that should stop u-joint vibration I was getting with the 4" of lift.
    The 35" tires fit nicely & I have the same ride quality that I had with 32" tires. I left a little rake to anticipate some extra weight in the back.
    The end result with 5" total lift:
  1. Replies: 35
  2. Pin Up Calendar...""site Donation"".
  3. Replies: 36
  4. VX "Rattles" & "Squeaks" over time
    Last Post: 03/15/2007, 07:36 AM
  5. "D" and "Low" Dash indicator jumble
    By Boogieman in forum VX Troubleshooting...
    Last Post: 09/28/2006, 09:07 AM
