As you see, I ended up buying the KMC XD's...
 VXer
						VXer
 VXer
						VXer
						My monster in progress...
Still need additional lift after the 3" BL and 1.5" torsion crank. Anyone know a good way to gain an additional 1.5" front and rear??? ( I am maxed with the torsion crank on one side, most likely due to bad indexing ).
 Super VXer
						Super VXer
						 VXer
						VXer
						Looks can be deceiving...
Quoted from my other thread. I must do like a 5 point turn in reverse to backup good, bad turn radius.I used a small hand saw to cut the piece of cladding that stuck out. It is still very close, turning seems fine while going forward, reverse is going to need some work, does not turn to well in reverse.
Plus the rear is very close too....
Anyone know why it would be differrent in reverse than going forward???
 VXer
						VXer
						Does anyone know what 'Zoid means under my username???
 Super VXer
						Super VXer
						I see. 35's... that's a meaningful step up from the 32.58" OD on the 285/65's of the same tire that Jeeperkate and I are running.
Didn't look that dramatic in the pics though.
-V
 VXer
						VXer
						 Super VXer
						Super VXer
						Looks good
You need to re-index the torsion bar- you can get at least 4" from the IFS. It won't be a fun job but necessary to give you enough turning clearance in the front. 2" IFS lift works well for me but I did a lot of wheel well cutting.
Also, you can get adjustable links from Indy to get the rear tire pushed back in the wheel well. You'll need all three links to adjust the pinion angle properly. The tire being forward shouldn't cause any problems... just looks weird. I had the same issue before the body lift but not anymore. Maybe your tires are a little taller because of the 18" rims vs my 15" rims.
 VXer
						VXer
						Do you know of anyu walkthroughs on re-indexing? Any special tools needed?
What about spacer in the rear and ball-joint flip in the front to add more height?
Since vehicles "float" on the suspension, that's why you can see some difference in reverse (vs forward). As you back up, the body floats/pitches forward. The opposite happens traveling forward.
Also, the rear chassis tend to pitch downward on launch. For reverse, the front would pitch down.
Nice looking Proton!
 VXer
						VXer
						Is the torsion bar adjust the only way to gain height in the front? Will longer shocks add more height?
 VXer
						VXer
