I gave up on the American Racing Chambers for now so I was comparing 2 other rims. Since Iv'e had many headaches about rim combinations and how much the offset will cause the tire to stick out I have made an excel chart comparing dimensions ( I know they are slightly off in some regard, but only by 0.1" because of no way to input tire sizes such as 35x12.50r18 on "http://www.rimsntires.com/specs.jsp", had to go with closest approx. of 315/70 r18 instead ). I want to check what you all think. Do you think the chart is fairly accurate? Chime in, let me know. If it proves good it will be easier to calculate how much a tire will stick out compared to another. Thanks.
Edited 10/17/2011 - 3:03PM STD Eastern time
Size of tires compared:
stock = 245/60R18
On the ProComp = 35x12.5R18
On the KMC XD = 35x12.5R18
Little Beasts = 33x12.5R18 ( ooops, I meant R20, thanks LDub. But if you see my excel, it lists 20, so the comp is good )
35x12.5R18 is the tire im looking to get wheels for ( thats why Im comparing the ProComps and the KMC XDs )
					 Rim / Tire / Offset comparison
