Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Blower Functioning Intermittently
  1. #16
    Jul 2011
    2000 Proton Yellow #0586 CROSSCHECK
    Yes Sir I am! And so thankful I can warm up my car from inside while I eat my breakfast and it be cozy inside when I go to work each morning. CANT. WAIT. FOR. SNOOOOOOOOOOWWWWWWW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
  2. #17
    Oct 2011
    01, Silver, VX
    Same problem here. Glove box doesnt work. Im going to get the resistor. Where is it located? I'll check wiring first before I order.
  3. #18
    Oct 2011
    01, Silver, VX
    Jul 2011
    In the "downloads" section on the site there is a manual that gives the all the diagrams for everything. Blower motor and resistor are there too. Look in the index. It showed me where they are and how to get them out
    Since you have a 2001, I don't think it is your resistor. In the 2000 and 2001 models, they had auto climate control or whatever, so there is no "variable resistor network" thing. You can pull out the resistor if you want. I have a 2000 and did so, but it is a circuit board with a large transistor on it. That was it. No network of resistors. So that might help you. Check the motor.
  5. #20
    Oct 2011
    01, Silver, VX
    took mine out
    I took my resistor out last night and put it back in today and now my fan is working like it should. However. I pulled the black cover off to see under the 3 connectors and seen the actual resistor, a capacitor, and something else. It has a heat sink connected to it so I don't think that part is just a resistor.
    Is there a cabin filter to change out on the VX? I guess the box that I unscrewed the "resistor" from is the "squirrel cage?" Because it had dust, dirt, debris in the bottom of it.
  6. #21
    Jul 2011
    Did the something else look like this?
    I just made that picture show up! Ha! Made my day!!! Wahoo!!!!!!!!!!!!
    Last edited by Breezy : 11/03/2011 at 06:21 AM Reason: I made a picture work!!!!!!! :)
    "Therefore we conclude that a man is justified by faith without the deeds of the law. -Romans 3:28
  7. #22
    Oct 2011
    01, Silver, VX
    no
    no, it was just a solid black block, with 3 connectors on the end that screws into the air box directly behind the glovebox. On the otherside is has a silver metal heat sink. I will post a pic or link soon.
  1. Members map functioning?
    By wekilled in forum Site Questions & Problems...
    Last Post: 02/20/2015, 12:25 AM
  2. ABS light on intermittently
    By DeepSilentComplete in forum VX Talk...
    Last Post: 06/14/2009, 07:00 AM
  3. A/C blower fan
    Last Post: 05/08/2009, 11:10 AM
  4. A/C Blower Fan Resistor
    By Sean Rogers in forum VX Talk...
    Last Post: 12/08/2008, 07:16 AM
  5. Remote not functioning?
    By JAFO in forum VX Troubleshooting...
    Last Post: 01/24/2003, 10:31 PM
