Well guys life has a way of throwing you curve balls. Our son is currently deployed to Kuwait and we are now taking care of his daughter part time. After some long discussions we've decided to sell a couple vehicles and get a vehicle that will better accomodate our grandchildren, currently at 7 (as of Monday). Needless to say our life has been in a bit of turmoil. So my VX is one of the vehicles we are considering selling. So I am left pondering what to ask for the VX. As most of you have seen my build, pretty much a complete mechanical rebuild. Some highlights:
Full engine rebuild using OEM parts where available.
modified the pistons with additional oiling holes
new OEM crank
rebuilt heads
complete new timing set
water pump
the works!
Full rebuild of transmission
New rear axle seals (serious pain to replace)
New upper and lower ball joints
New inner and outter cv boots
All new brakes
Tires were installed new when the build was finished
Frame sanded and sealed with Master Series Coatings
The list goes on. We've got around 10K miles since the rebuild and have enjoyed every mile. I know there is a list out there but I think I can save time and tell you what I know is bad. I have never had the door panels off and it suffers from the window ailment. I have the SBC brackets but have not installed them. The engine has an oil leak, best I can figure is the rear seal was not put in properly and leaks probably about a quart per 5K miles. I think I made Merlin salesman of the year when building this thing and I can provide the reciepts of the parts.
So what does the group say. What would be a reasonable asking price for my XV?
Thanks in advance.....
Greg
