So wait, you can move our LSD clutch packs into a rear 4.77 3rd member?
Hmmmm.
Dude...
Did you do due diligent research? (as in : read the thread)
I'm roll'n 35's & 4:77's...
Also, the fact that you always run your A/C, isn't germane to my statement...
I was trying to explain my perception of the difference in acceleration between stock & 4:77 gearing...![]()
I have 33's w/stock gearing. I like LDubs analogy about the A/C.
BUT, i realized a caveat recently. It depends on exhaust! When I posted that the off the line feel was not that different than stock, I had a much more open exhaust than I do right now. Back then I had a Cherry Bomb Vortex muffler (similar to Flowmaster 40). Recently I added a SuperTrapp with 24 disks to tame it a little. It gave better tone and higher RPM torque due to back pressure increase, but low-end torque dropped a little. It bogs SLIGHTLY from a stop if throttle is aggressive. Once up to 2300ish RPM and WOT, it screams (as much as a 3.5 can...).
But, less restricted... yes, much better off the line.
SilverBullet75
Formerly: '01 Ebony VXSTLTH
Now: '08 Saab 9-7x Aero 6.0L
Who's not reading? My question was directed to SilverBullet75. And I got your comparison, but seeing as I run with the A/C on all the time, that would be double s**t for me. Air on and stock R&P with 33" tires........get it? Double s**t, Maddawg driving around with the windows down in 105 deg temp in order to gain acceleration, lol. I do diligent research all right, I just have CRS! But thanks anyway!!
Check the tude at the door please...
I replied in a effort to relate my perceived difference between stock & 4:77's...you know, to help you out.
If you had actual comprehension of what was said, you would be able to figure out that the DIFFERENCE in acceleration, with & without the A/C on, is what I was referring to...you DO know that acceleration is slower with the A/C sapping some of the power...right?
...You quoted me when asking this question...so I thought the query was directed @ me...
If you even had comprehension of the TITLE + author of this thread, you wouldn't have quoted me, OR asked that question.
Can't hardly wait to be of help again...
So is the honeymoon over or are we establishing the pecking order here? C'mon Ldub smile. XOXOXOXOXOXOXOXOX.
What are you doing awake at these wee hours of the day dub?
