If the gears are already in a third member, you can swap the third in without requiring professional gear set-up. One of the nice things about the third member design.
Oh, and stock 245/70 = 29.5" diameter, so 33" represents 11.8% difference from stock. Ideally you want a similar change in gearing.
4.30 to 4.56 = 6.0%
4.30 to 4.77 = 10.9%
So 4.77s are pretty ideal for 33s.
So wait, you can move our LSD clutch packs into a rear 4.77 3rd member?
Hmmmm.
Yes, and not only that but I went on search overload when I found out that a turbo Isuzu Impulse had a 10 bolt LSD in the rear that will fit perfectly into a set of 4.77's on the front of the VX as well ;-)
All the junkyard Impulse Turbo's that I found were missing the diff though :-(
Who's not reading? My question was directed to SilverBullet75. And I got your comparison, but seeing as I run with the A/C on all the time, that would be double s**t for me. Air on and stock R&P with 33" tires........get it? Double s**t, Maddawg driving around with the windows down in 105 deg temp in order to gain acceleration, lol. I do diligent research all right, I just have CRS! But thanks anyway!!
Check the tude at the door please...
I replied in a effort to relate my perceived difference between stock & 4:77's...you know, to help you out.
If you had actual comprehension of what was said, you would be able to figure out that the DIFFERENCE in acceleration, with & without the A/C on, is what I was referring to...you DO know that acceleration is slower with the A/C sapping some of the power...right?
...You quoted me when asking this question...so I thought the query was directed @ me...
If you even had comprehension of the TITLE + author of this thread, you wouldn't have quoted me, OR asked that question.
Can't hardly wait to be of help again...
So is the honeymoon over or are we establishing the pecking order here? C'mon Ldub smile. XOXOXOXOXOXOXOXOX.
What are you doing awake at these wee hours of the day dub?
