Hey All,
it seems when i pull out from a stop that the transmission is starting in 2nd gear,takes a while to build up rpms and then shift..then runs fine thru the rest off the gears and down shifts when coming to a stop.
if i manually shift from 1st to 2nd to 3rd to drive or even from first then to drive once i get the rpms up every thing is fine.
this ever happen to anyone?
, oops....
