Mine had leftward turning resistance. I replaced the steering gear. Steering gears are cheap used. Go to the used part finders and search for a same year Trooper steering gear and you will find tons of them.
Did you replace it yourself or a shop? If a shop do you mind me asking what it cost in labor?
Thanks!
Found another link with the Vehicross as root:
http://www.catcar.info/isuzu/?st=50&...fHxuaT09MDE%3D
Steering gearbox return hose. P/N 8-97178427-1
It's like $25 bucks from Isuzuparts.com or call st. Charles. You can replace it, just be careful putting it back onto the plastic reservoir or you'll snap the bung off and have to replace the reservoir. Good news is the reservoirs are now back in stock![]()
Replaced myself. level of difficulty was moderate. If I remember pulling the pittman arm off wasn't easy ..you need a good puller. You might get lucky and receive a steering gear with one. Remember it goes on keyed. I had a mechanic do it first and he rammed it on. I had to do his work over cause I lost my turning radius to the right...he didn't center the arm back on correctly.
