Results 1 to 15 of 26
Thread: Flywheel off or broken timing belt/chain?
    Jul 2011
    2000 Proton Yellow #0586 CROSSCHECK
    I was driving to church when suddenly the RPM starting bouncing at redline and the engine wasn't connected to the tranny at all. No pull whatsoever. I immediately thought maybe my drive shaft fell off. No. Checked it. Good. Now she wont start. Wont even turn over. She got towed. I just had the tranny replaced. Suggestions so far were that the flywheel came off somehow...? Or the timing belt/chain (which one do we have?) broke, which also makes sense. Also, are our engines interference engines? I'm sure hoping not...
    Nov 2007
    1997 SILVER
    Mine would probably do the same thing if it knew it was going to church.
    That aside, it definitely is not the timing belt.
    When you try and start it, does it make a low whirrrring sound, or just a click??
    Whirring sound means your flywheel has become disconnected and also suits the other symptoms.
    Click could mean other things have happen like a seized engine etc.
    Now, it depends on what the transmission guys did, as to whether they had the flywheel off. They should not have had it off, but maybe they did.
    Good luck.
    PK
    Quote Originally Posted by Breezy View Post
    Good news for you....Our engines are NON-interference....it's been debated and discussed a lot....even some repair manuals say it's an interference engines...WRONG! It's not. Somebody's timing belt just recently blew, and caused no damage....that further helped confirm this.
    X2 what PK said...and Sue too.
    2001, Dragon Green, 1342
    X2 what PK said
    about going to church?
    makes me wonder IF they failed to torque the converter bolts to the flywheel/flex plate and they sheared
    Aug 2005
    1999, silver, 0887
    Post
    Sounds right.
    Jul 2011
    PK- It is most definitely a low whirring sounds. No clicking or anything. Assuming its the flywheel, is this an expensive fix? The tranny shop is the same company that towed it last night, so I'm expecting them to cover costs. Should I? Would my flywheel naturally fall off or crack without someone miss-torquing something?
    Feb 2009
    1999,silver, 1516
    I've not heard of this happening to a single VX. I'd definitely suspect the shop did something incorrectly...
    Jul 2011
    Transmission shop claims no responsibility. They said they don't touch flywheels. It's just my luck to have one break off 2 weeks after my tranny swap...I'm going in to the shop after work and they are going to show me what happened to it. I guess to replace it the tranny has to come out completely again...This car has just been a money pit since I got it. So frustrating.
    Sep 2010
    2000,Ebony,VEC,0013
    Mine gets happy going to church...and meeting its friends, and I get happy when the preaching begins!!
    Quote Originally Posted by Ebenezr View Post
    I usually
    Then, suddenly wake with a jolt, when I realize I've burst into flames...
    Jun 2011
    2000 Kiaser 0275
    i would not take no for an answer, i am a mechanic myself with out actually seeing vehicle i can obviously not be much of a help but if i had replaced a tranny on a vehicle and 2 weeks later the flex-plate broke (flywheel is only on manual tranny auto tranny has a flex-plate.) i would assume that something i had done was most likely the cause. or at very least i should have noticed it was damaged before reinstalled the tranny. i suspect that if it is the flex-plate that one of the following may be the cause, they actually did take off flex-plate and did not re tighten it properly, that they may had damaged it while taking tranny out or reinstalling it or possibly the torque converter was not installed properly or had something on it when it was installed and was trapped between flex-plate and torque convert, and was ok for a while but eventually flex plate fatigued under load and high temps that torque converter reaches.
    if i were you i would try to be there when they pull tranny out so they don't have time to hide anything from you if it is there fault.
    hope this help and best of luck
    Jul 2011
    Thanks mantis. But I went to the shop yesterday and they showed me the problem. New flexplate should be here today (hoping) and I'm paying for them to fix it. I can't prove they did anything wrong. I asked them specifically about all the things they could have done wrong that would have caused this and they claim to have done everything correctly and have properly inspected all the parts before installation. I can't argue with that. If a man gives me his word and I can't prove him wrong, I just have to accept it. So I can only trust that they are being honest with me =/
    Feb 2010
    2001,Kaiser,1130
    Make it clear to them that you can no longer recommend their service to anyone you know. The probability of your flexplate failing is already ~ 0, add in that they did remove the transmission, and this entirely indicates that they are really trying to rape you. Why would you pay the same shop to fix what they broke? Go to a different shop if you feel that they won't fix it for you and you have to pay anyways. Otherwise, they will just keep raping you. Next time, you'll notice that the TOD mounts have failed, and the transfercase needs to be replaced.....
    Get real Breezy - no one in these sorts of business is honest.
    Sep 2010
    2000,Ebony,VEC,0013
    Not to throw salt on your wounds but my engine went bad at the same time my trans was reworked. The trans man kept it for several more weeks and put some significant time into it trying to solve the problem. He did it free of charge. He didn't have too.
  1. Did I screw up my timing? Timing belt replacement
    By workmeistr in forum VX Troubleshooting...
    Last Post: 04/13/2015, 07:26 AM
  2. Broken Flex-plate/Flywheel
    By svbigtuna in forum VX Talk...
    Last Post: 08/15/2011, 11:07 PM
  3. Timing Belt Broken...
    By kronopoliz in forum VX Troubleshooting...
    Last Post: 05/05/2010, 04:41 PM
  4. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 08:09 PM
  5. Timing belt replacement and timing videos
    By deermagnet in forum Archives
