Anyone know an easy way to get the bolts on the lower ball joint off. They are resessed in the a arm so far can't even barely get a socket on to them. Had to just replace both front calipers they both locked up at the same time and I want to replace upper and lower ball joints and tie rod ends but can't get these damn bolts off! Thanks in advance
on top, & a deep socket on the bottom.
